Moving slow and Foul smell - Nissan Xterra Forum: Xterra Forums
Old 01-01-2013, 11:47 AM
ltarry ltarry is offline
Member: #3128
ltarry is on a distinguished road
I have a 2008 Xterra Off Road (manual transmission) with 110,000 miles. I have never had any major work performed. (YET....)
However today, it was having issues move forward/backward. I can get it into gears and the clutch seems be engaged. Also I smell a foul odor...not a burning smell but like a rotten egg.
What could be the possible root cause(s)? And how much of a repair bill am I looking at?
Thanks in advance for our expertise (and pulling me off the ledge...lol).
Old 01-01-2013, 12:29 PM
Chef's Avatar
Chef Chef is offline
Member: #30553
2003 Xterra
Chef is on a distinguished road
Sounds like a toasted clutch
Old 01-01-2013, 02:53 PM
mexfdmnb's Avatar
mexfdmnb mexfdmnb is offline
Member: #35567
2007 Xterra
mexfdmnb is on a distinguished road
go check your coolant make sure its still the right color cuz if it has any red or brown in it the internal tranny cooler might have gone bad
2007 Xterra S
K&N filter
Tranny bypass mod
Sound System
Old 01-01-2013, 03:04 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
That's only an issue on the automatic transmissions.
Old 01-01-2013, 03:29 PM
mexfdmnb's Avatar
Member: #35567
2007 Xterra
whoops yep your right my bad didnt read carefully enough thanks for having my back
2007 Xterra S
K&N filter
Tranny bypass mod
Sound System
Old 01-01-2013, 04:25 PM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
rotten egg smell is usually a fouled cat converter. try putting your hand over the tailpipe firmly while its idling if it doesnt try to push your hand off or doesnt have much pressure on it thats a sign of a bad or failing cat. converter does it have a check engine light on? if so get us the code(s)
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
Old 01-01-2013, 05:19 PM
Member: #3128
No, check engine is not on.
Thanks for the responses
  #8
Old 01-01-2013, 05:27 PM
kms1990's Avatar
Member: #34507
hm, check your oil and your coolant also your gear oil and make sure theyre in good shape and full wouldnt hurt to check your clutch fluid either. rotten egg means sulfur somewhere it shouldnt be. look under your car for holes in the exhaust and/or cat converters. as chef said earlier though you may have a toasted clutch. have you done any heavy towing or hard take offs or popped the clutch alot recently?
My Laundry List
LIFT()
MUD TIRES()
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
  #9
Old 01-01-2013, 05:51 PM
Chef's Avatar
Member: #30553
2003 Xterra
If the engine is running fine and you have no codes but you shift and nothing happened then most likely the smell you smell is the last of your friction plates. Not sure on prices for the job on this truck but on my 92 trans am it was 500
  #10
Old 01-01-2013, 06:51 PM
kms1990's Avatar
Member: #34507
yeah go with what chef said that sounds like a good way to start delving in
My Laundry List
LIFT()
MUD TIRES()
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
