2002 SE Supercharger Sound - Nissan Xterra Forum
post #1 of 5 Old 12-30-2012, 09:57 PM Thread Starter
Gsimpson2G
Seasoned
Gsimpson2G's Avatar
Gsimpson2G is on a distinguished road
So, when I first picked up my X, I thought the supercharger sounded awesome. After watching a few videos of supercharged X's, I don't think mine sounds so normal now. Instead of a wine, it has a rushing of air sound. Engine appears to be stock. Does this sound normal? I have never had a Supercharged vehicle before.
Gsimpson2G is offline
post #2 of 5 Old 01-01-2013, 02:30 PM
iwashmycar
iwashmycar's Avatar
Quoted: 1 Post(s)
2003 Xterra
iwashmycar is on a distinguished road
On many OEM supecharged vehicles you get more sound with aftermarket cold air intakes and even a reduction pulley. I dont personally know what an XTerra sounds like supercharged and stock, but I am sure Nissan did not want it to be all too loud!
-Adam
2003 Nissan Xterra XE 2WD AT
2007 (O|TOYOTA|O) FJ Cruiser 4WD AT
iwashmycar is offline
2003 Xterra
post #3 of 5 Old 01-02-2013, 11:06 AM Thread Starter
Gsimpson2G
Seasoned
Gsimpson2G's Avatar
Well, drove it today, and now the supercharger has a nice wine to it, and she pulls up hills much better. Stopped at Autozone to pick up some Seafoam, and had them check for codes on it. Only one that pulled up was the Knock Sensor code. Sadly, he couldn't clear the codes for me . Will disconnecting the battery clear the code for me like with other vehicles, or will it clear itself over time?
I have a feeling it had some old gas in it when i got it. First time I filled it up, it reeked when I opened the gas cap. Probably what threw the code, unless the sensor has gone bad.
post #4 of 5 Old 01-02-2013, 11:48 AM
intender
intender's Avatar
Quoted: 1 Post(s)
2000 SE Xterra
Garage
The knock sensor is probably bad. That and the distributor are probably the two most common problems on an xterra. Most people just ignore it since it doesnt cause the light to come on, but on a boosted engine I would probably fix it.
<<<-click for build
intender is offline
2000 SE Xterra
post #5 of 5 Old 01-03-2013, 10:32 AM
Mirage
Quoted: 1 Post(s)
2003 Xterra
Mirage will become famous soon enough Mirage will become famous soon enough
the knock sensor code will cause the sc bypass valve to open, causing you to have reduced boost/power. try asking if you can clear the code with their scanner, or go to another parts store (some won't clear it themselves, but will let you clear it). drive it for awhile and see if it comes back.
Mirage is offline
2003 Xterra
