Recommeded Offroading gear??? - Nissan Xterra Forum
post #1 of 21 Old 12-30-2012, 10:40 AM Thread Starter
scott-bc
Seasoned
scott-bc's Avatar
scott-bc is on a distinguished road
In the near future I plan on arranging a local 4x4 trip and would like to get some additional feedback on what are the necessary things to bring for your truck and for myself while out 4x4'ing. As we always try to be safe there could be a time where a 1 day trip could lead to an overnight due to weather or breakdowns. I generally have a good idea of what to bring. See list below. If I have missed something please let me know.
- Small Jerry can with gas
- shovel
- hi-lift jack or some type of jack.
- flashlight
- sleeping bag
- food
- first aid kit
- tool kit
- heat pads(location dependant, could be cold in the night without heat)
- water
- Beer
Now the question I have is what about spare truck parts?
scott-bc is offline
post #2 of 21 Old 12-30-2012, 10:51 AM
maillet282
maillet282's Avatar
2009 OR Xterra
maillet282 is on a distinguished road
I would carry spare fuses,
tire plugs,
Socket set with wrenches
zip ties
duct tape
a tarp to throw under the truck as a barrier from the snow/mud
small air compressor ( or OBA tank)
small hand saw ( metal and wood blade)
build thread:
My 09 Xterra
maillet282 is offline
2009 OR Xterra
post #3 of 21 Old 12-30-2012, 12:08 PM
Drake
Club Xterra O.G.
Drake's Avatar
Drake is a splendid one to behold Drake is a splendid one to behold Drake is a splendid one to behold Drake is a splendid one to behold Drake is a splendid one to behold Drake is a splendid one to behold
Spare auto-hubs and tie-rod adjusters is a must in my opinion. If you can only do one or the other, tie-rod adjusters. You can always limp out in 3WD or 2WD as long as you are NOT ALONE.
Other stuff in no particular order:
tie-rod ends
centerlink
idler arm (if you don't already have an idler arm brace then this would go into the must carry category)
CV axle
torsion bar anchors
torsion bar adjusters
Drake's Build Thread
Drake is offline
post #4 of 21 Old 12-30-2012, 12:55 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
To add to the list
Spare tire
Tire repair kit
Fire extinguisher
Also see this thread for more info http://www.clubxterra.org/forums/showthread.php?t=19645
RacerXXL is offline
2000 XE Xterra
post #5 of 21 Old 12-30-2012, 12:59 PM
iwashmycar
iwashmycar's Avatar
Quoted: 1 Post(s)
2003 Xterra
iwashmycar is on a distinguished road
Here is what I have found to be very important. I usually go to ORV parks with a group, so overnight stays and even recovery gear isnt necessary on my part.
CB
Rubber floor mats like Husky Liners
Tire Deflators
Snatch Strap and D-Rings
Camera (gotta get those sweet offroading pics for the forum!)
-Adam
2003 Nissan Xterra XE 2WD AT
2007 (O|TOYOTA|O) FJ Cruiser 4WD AT
iwashmycar is offline
2003 Xterra
post #6 of 21 Old 12-30-2012, 08:22 PM
Tarditi
Tarditi's Avatar
Quoted: 7 Post(s)
2006 Xterra
My old 4x4 club came up with this list:
http://www.cnc4x4.org/mini_equipment.asp
If you're going with friends, FRS radios are pretty cheap and easy to use - not everyone has a CB. I wouldn't recommend going solo.
Make sure you save the beer just for the campsite, too... ;-)
Dustin Tarditi
Raleigh, NC
2006 Granite S
Tarditi is offline
2006 Xterra
post #7 of 21 Old 12-31-2012, 09:16 AM
slightlywicked76
2012 Xterra
slightlywicked76 is on a distinguished road
I added Silicone Rescue Tape to my kit, just in case of a leak in the cooling system. It can be used to temp fix a hose. Plus it is great for wiring.
"African Family Truckster"
[x] PML
[x] 265/75R-16s
[x] Light bar w/KCs
[x] LoPro Roof Rack (self made)
[x] Front, Engine & Trans Skid Plates (self made)
[x] Bilstein 5100s all the way around
[x] Warn Manual Hubs
[x] Idler Arm Brace
[x] Transfer Case Skid Plate (Shrock)
[x] Replace Headliner
Life in the Congo is tough, it is tougher with a weak truck!
slightlywicked76 is offline
2012 Xterra
post #8 of 21 Old 12-31-2012, 09:26 AM
Drake
Club Xterra O.G.
Drake's Avatar
I couldn't stress this enough. Take it from a lot of bad experiences from my teenage years just getting into offroading (in a POS blazer). I've had to walk several miles multiple times to find rescue.
Drake is offline
post #9 of 21 Old 12-31-2012, 12:24 PM Thread Starter
scott-bc
Seasoned
scott-bc's Avatar
Thanks for all the great feedback. Here is what I have collected so far.
- shovel
- flashlight
- sleeping bag
- food
- first aid kit
- tool kit
- water
- Beer
- spare fuses
- tire plugs
- Socket set with wrenches
- zip ties
- duct tape
- tarp to throw under the truck as a barrier from the snow/mud
- small air compressor ( or OBA tank)
- small hand saw ( metal and wood blade)
- Spare tire
- Tire repair kit
- Fire extinguisher
- tie-rod ends
- centerlink
- idler arm (if you don't already have an idler arm brace then this would go into the must carry category)
- CV axle
- torsion bar anchors
- torsion bar adjusters
Some of those mechanical items ie. an axle really? Must be fom experience?
Why the torsion bar anchors and adjusters? Don't understand this one.
scott-bc is offline
post #10 of 21 Old 12-31-2012, 12:49 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
An axle really.....yes. The front CV's can and do break, I broke one this weekend but got lucky and it was at the end of the day so did not have to change it on the trail. I carry a spare and we have some members who carry more than one.
Torsion bars can break but usually it is the anchor or the adjuster that the splines end up stripping out. The torsion bars are the springs for the front suspension and are supporting the weight of the truck. When one breaks or strips splines the front suspension on that side will collapse and you are going to be pretty much stuck.
RacerXXL is offline
2000 XE Xterra
