Has anyone ever made there own revolver shackles? I'm thinking I am going to make some, any input and or detailed pictures of your shackles would be greatly appreciated!
Why would it be that hard? I have looked through hundreds of pics and it basically boils down to two shackles that are connected by a rotating piece. If I'm missing something please tell me before I start lol
Well the inside is hollow to allow it to be grease able which will be fairly difficult.
The rotating piece is the real hard part. If you have a plan for making that part then by all means you got it. The rest of the shackle is Easy. Cut the desgin out of a plate or two of Steele. Weld them together. Use a drill press to drill out the holes and Bingo you have a shackle. The problem I would see would be getting the Revolving part created that is strong enough to do its job.
I have seen other people take two shackles and put them together to get what is basically a folding shackle. Not sure how reliable that is. I personally wouldnt do it. It could give you more articulation, but you would have to come up with some way to keep them from folding in the wrong direction. the revolvers add in the advantage of having the center section that twists as well as folding. This relieves the twisting forces exerted on the leaf springs. It probably isnt impossible to make your own revolver, but like Shiftingskys said the rotating part will be the hard part. I am all for making your own stuff, and god knows I have cut stuff and welded stuff on my truck quite a bit, but the suspension just isnt the kind of thing I would feel safe fabricating my own parts for.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
I am taking metal fabrication at school so this might be an interesting project for my second semester to make and then tweak and make again but better. I will talk with my instructor ( he is in to jeeps so he knows quite a bit about all this stuff) and see what he thinks.
Alright let us know. It would be cool if you can make them. Maybe make you some money . If you can figure out how to make the revolving mechanism then you got it ez. If you need ANY pictures of the revolver shackes in RL then I can get them for you if needed. Obviously installed on the truck.
