SES Light coolant related? - Nissan Xterra Forum: Xterra Forums
Old 12-27-2012, 10:55 AM
btblue btblue is offline
Member: #35674
2002 SC SE Xterra
btblue is on a distinguished road
I have a 2002 Xterra SE SC with 90,000 miles on it with no past history of problems. Last night in the middle of a 30 minute drive, the SES light came on solid. Checked gas cap, wiring, air hoses, but found nothing. The only thing out of the ordinary was the coolant tank was empty. I have noticed a little drip here and there over the past few months, but nothing major. I plan a timing kit replacement in the spring, so figured it could wait till then. The big question is whether low coolant will cause the light, and if so, will it go out on its own since I have refilled the tank? The X runs fine...for now!
Old 12-27-2012, 07:07 PM
cbxterra cbxterra is offline
Member: #18847
got access to a code reader? maybe one at an auto parts store. once you get the codes someone can help a bit more. I don't know a whole lot- learning as I go. But I doubt an empty coolant reservoir [I assume you mean the overflow tank] would trigger a code. But I'd watch the coolant level. IF it's going down quickly or you've got WHITE smoke out the tailpipe that's a whole other bowl of wax- possible head gasket. Some first ideas to think about, hope it helps a bit
Old 12-27-2012, 08:49 PM
Cyclemut's Avatar
Cyclemut Cyclemut is offline
Most Halal Mod
Member: #2547
02 Xterra
Cyclemut has a spectacular aura about themCyclemut has a spectacular aura about themCyclemut has a spectacular aura about them
The only code that it could throw is an over-temp code, but more than likely, you would have noticed it overheating.
Nissan Sport Magazine
The world's only Nissan specific mag!
Old 12-28-2012, 06:03 AM
Member: #35674
2002 SC SE Xterra
I went to have codes read at Autozone last night. First one was P0328 knock sensor (KS) circuit high input, and the second one was P1491 vacuum cut valve bypass valve. I should mention that my dad and i replaced the plugs a month ago with some degree of dificulty. The SES light just came on a few days ago, so I can't imagine that has anything to do with the current situation. The truck still starts and runs just fine. Thanks again for any help.
Old 12-28-2012, 09:52 AM
Member: #18847
important one is the vacuum one. the knock sensor seems to be common and not much problem [usually safe to ignore in non supercharged truck]. look in form "repair questions". there's two sticky there- one on the knock sensor and the other a link to the factory manuals. look up the section on engine control. there's a list of codes and how to figure out what's up and how to fix it. good place to start
Old 12-30-2012, 07:02 AM
outwiththeold's Avatar
outwiththeold outwiththeold is offline
Member: #4028
00 Xe 4x4 Xterra
Here it is, I had to replace mine last year.
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
Old 01-16-2013, 09:16 AM
Member: #35674
2002 SC SE Xterra
All is well!
I bought some Lucus Oil octane booster and filled up with premium fuel since I had been using 87 for some time. After about a week, the light went out, so I have no idea why the vacuum error code cleared itself. Now I just hope it doesn't come back for a long, long, time.
  #8
Old 01-16-2013, 10:42 AM
Member: #4028
00 Xe 4x4 Xterra
It will, mine went on and off for sometime before it stayed on, and that’s when I had to replace it...
