02 Sensor part number Front Left, Upstream - Nissan Xterra Forum: Xterra Forums
Old 12-26-2012, 09:53 AM
PlayerZer0's Avatar
PlayerZer0 PlayerZer0 is offline
Member: #31025
PlayerZer0 is on a distinguished road
Ok,
does anyone have a part number for the upstream-left O2 sensor ? I have purchased the NTK 24805, and the Bosch 18002. and Neither of the Threads are correct on it. As if right now, we have replaced all the O2 sensors on the leftside, just to be logical, and the next step for me, is to just replace the entire CAT.
Oh BTW, Happy Holidays and I am glad to be back statside!
Now if i can just get rid of this CEL..... which is throwing the infamous p0430 code.
( •_•), ( •_•) + <⌐■-■ = (⌐■_■)
I wear my sunglasses at night
Old 12-26-2012, 11:26 AM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Is the problem that the replacements are a totally different size then the original? If so you probably have the correct one but the upstream O2 sensors are actually threaded into an adapter. Problem is the adapter tends to be frozen to the O2 sensor.
This is from a write up I did on installing headers but it should help. Just remove the adapter from the old O2 sensor and transfer to the new one.
Take the cat to your work bench and using a 22mm wrench remove the O2 sensor. Unlike the down tubes you will notice that the sensor is not threaded directly into the cat bung but is instead threaded into an adapter. On mine the sensor was frozen in the adapter and both came out together. Simply place the O2 sensor adapter in a vice, tighten the jaws on two flats, and remove the O2 sensor from adapter.
Old 12-26-2012, 05:20 PM
PlayerZer0's Avatar
Member: #31025
YEAAAAAAAAAAAAAAAAAAAAAAAH <---- did a dummy thing. the entire nut/flange thingy came off when we took off the old O2 sensor. i noticed it right when i was looking at it today, so we just took it apart and got it all fitted in now.
Old 12-26-2012, 05:21 PM
PlayerZer0's Avatar
Member: #31025
Unfortunately, it didnt fix the problem. Next step is to replace the cat-convetor, which is what i believe, phrog man did
Old 12-26-2012, 09:38 PM
xtacular's Avatar
xtacular xtacular is offline
Member: #13879
Did you reset the light? It won't go out very quickly after fixing the problem.
2002 Super Black 5 Speed 4x4
Shovel Mount
Old 12-27-2012, 07:43 AM
PlayerZer0's Avatar
Member: #31025
Well, i unhooked the battery for about 15 minutes to reset the computer, but it still didnt go away. im goign to be taking it to advanced auto today to get the computer reset
Old 12-27-2012, 08:48 AM
intender's Avatar
intender intender is offline
Member: #30982
they wont do it more than likely. they might let you take the scanner and do it, but some stores wont do that either. not sure if they let rent their scanners or not, but if they do that will probably be your best option.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
  #8
Old 12-27-2012, 10:28 AM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
autozone should erase it for you or leave it unhooked for more than an hour to reset. which codes did you have?
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
  #9
Old 12-27-2012, 11:56 AM
PlayerZer0's Avatar
Member: #31025
I took her to advanced auto, and they did it for me this morning, i just got back from driving about 70 miles. Hasnt thrown a code yet.....
  #10
Old 12-27-2012, 11:58 AM
PlayerZer0's Avatar
Member: #31025
Sorry, it was the P0430 code
