scary brake issue - Nissan Xterra Forum: Xterra Forums
Old 12-25-2012, 01:46 AM
mproctor90 mproctor90 is offline
Member: #38107
mproctor90 is on a distinguished road
scary brake issue
Hey everyone. New to the forum and I'm having a scary intermittent brake issue. Occasionally when I hit my brakes they will BASICALLY fail. What happens is the pedal gets hard and states to vibrate and shudder and severely lose braking power. Happens at ant speed and seems to happen with any amount of braking force. Also my ABS light comes on from time to time. Sometimes its on when this happens sometimes its not. Any help on the issue would be greatly appriciated. Thanks
Old 12-25-2012, 07:16 AM
outwiththeold's Avatar
outwiththeold outwiththeold is offline
Member: #4028
00 Xe 4x4 Xterra
What is your location? What is the abs code? Have you done any brake work on the x lately? You should check rotors, drums, calipers.
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
Old 12-25-2012, 08:49 PM
Member: #38107
i live in the northwest. rains a lot here. im not sure of the abs code, but i know the person i bought it from said the light comes on from time to time and they said it was something with the RF wheel speed sensor. i need to go get it read since i dont have the tool. but today i was driving and slammed on the brakes pretty hard just to see if maybe what i was feeling was the abs working and im pretty sure thats what it was. but it has previously done this when the vehicle was obviously not losing traction. i read somewhere that the sensor might just need adjusted or be dirty. how true does that sound. im just worried because its so intermittent.
Old 12-26-2012, 07:51 AM
Member: #4028
00 Xe 4x4 Xterra
To pull the abs codes do this...The abs will not work if the abs light is on...
Name:	abs ground with paper clip..jpg
Old 12-26-2012, 08:27 PM
Member: #38107
is reading the abs cods the same type of pattern as an obd 1 check engin light pattern (I.E: one long and 3 short flashes would make 13?) and where is the plug located. i just dont wanna short something out by jumping thewrong plug.
Old 12-26-2012, 08:34 PM
Member: #38107
and thinking back on it i dont think my abs light has ever been on when the x has done this. so thats good to know the abs does not wotk when the light is on
