Roof basket / rack - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Nissan Xterra Mods > Exterior Mods
Old 12-19-2012, 08:42 AM
Jack Stilts's Avatar
Jack Stilts Jack Stilts is offline
Seasoned
Location: Surrounded by Jeeps in an Xterra-less Michigan
Member: #33519
Jack Stilts is on a distinguished road
Roof basket / rack
Y'all:
One of the next items on my list is a roof basket / rack to mount onto the stock roof rails. I'd like to keep the stock rails rather than replace the whole rack with a basket. So far my only two options are the Thule M.O.A.B. and the bolt-together rack from 4x4parts. I plan to either bolt or strap down a spare up there, and have the standard attachments.
Does anyone have any experience with either of these? The Thule would accept all my other Thule attachments, but the bolt-together rack LOOKS like it will give me twice as much cargo space.
Suggestions? Thanks.
- Brian (Jack)
| 2002 3.3L 4x4 XE - the Terradactyl |
[x] K&N filter, rear sway bar & side rail removal, repaint trim
[ ] Gobi ladder and low-profile rack
[x] BFG Rugged Terrains
[x] Front & rear recovery points, LOBO, PML
[ ] Xoskel lightbar & PIAA lights, Mean Green alternator
[ ] Full armor - skid plates & sliders, hidden winch
[ ] IAB, Bilsteins, HD TRAs
[ ] Low-profile snorkel, CB installation
Build
Old 12-19-2012, 08:51 AM
maillet282's Avatar
maillet282 maillet282 is offline
Seasoned
Member: #28826
2009 OR Xterra
maillet282 is on a distinguished road
I am unsure if anybody has done this for a first gen but did you consider fabricting a drop in roof basket that would fit between the stock roof rails ???
build thread:
My 09 Xterra
Old 12-19-2012, 04:49 PM
drbandkgb drbandkgb is offline
nXm3 Sept 2013
Member: #8403
drbandkgb is a splendid one to beholddrbandkgb is a splendid one to beholddrbandkgb is a splendid one to beholddrbandkgb is a splendid one to beholddrbandkgb is a splendid one to beholddrbandkgb is a splendid one to beholddrbandkgb is a splendid one to behold
Yakima makes a rack... Load warrior
Its very nice... Also check out Hepsdesigns
He does a nice drop in rack..
Old 12-19-2012, 06:34 PM
Seasoned
Member: #33519
I forgot about Hep's basket...thanks Dave!
I could do everything I wanted with that. Hold all the standard accessories (Hi-Lift, shovel, axe, spare tire, gas cans) and I could maybe fit into my garage.
- Brian (Jack)
Build
Old 12-25-2012, 03:35 PM
Tay-Lo's Avatar
Tay-Lo Tay-Lo is offline
Member: #37277
Tay-Lo is on a distinguished road
I have a Surco safari basket that takes up the entire flat portion of the factory rails. It does add a lot of height to it to but I love it.
It screws together and is very rigid....also made in the USA. The clamps that hold it to the factory rails are pricy as well as the attachments but I figured I'll make those myself when I need them.
Old 12-26-2012, 02:43 AM
slightlywicked76 slightlywicked76 is offline
Member: #36773
slightlywicked76 is on a distinguished road
I built a drop in roof rack out of 3cm square stock (Here everything is metric, which made the measurements fun). I took out the stock basket and built the rack from the front of the factory rack (behind the air dam) all the way to the rear of the factory rack. I built the bottom part of the rack extending past the rear of the factory rack far enough so I could put a 5 gallon jerry can in it then built a extension off of the top part to wrap around the jerry can. I carry two spares when I go out and about because there is no AAA or tire shops once you get out side the city.
I have attached the pic of the test run before I painted it, but that is a full size spare, 5 gallon jerry can and 150qt cooler and if I wanted to I could get two coolers up there. I will try and get some pics uploaded later to show it.
However if you are building one of these I would suggest test fitting it often since there is a slight bend in the factory rack. Last thing you want to do is build a sturdy roof rack that doesn't conform to the factory rack and pull your factory rack out of the roof.
"African Family Truckster"
[x] PML
[x] 265/75R-16s
[x] Light bar w/KCs
[x] LoPro Roof Rack (self made)
[x] Front, Engine & Trans Skid Plates (self made)
[x] Bilstein 5100s all the way around
[x] Warn Manual Hubs
[x] Idler Arm Brace
[ ] Transfer Case Skid Plate
[x] Replace Headliner
Life in the Congo is tough, it is tougher with a weak truck!
Old 12-26-2012, 09:05 AM
Seasoned
Member: #33519
@ Tay-Lo - I've seen those...I think I'm leaning more towards being able to fit into my garage
@ slightlywicked76 - Thanks for that suggestion. That's all the stuff I'm looking to carry. I'd be glad to see some more pictures of that thing, if you get a minute!
- Brian (Jack)
Build
  #8
Old 12-27-2012, 01:19 AM
Member: #36773
Jack Stilts - I have attached some pics. It isn't the prettiest thing since there is no powdercoating shop here and cheap spray-on paint and brush on rust inhibitor is all I could find. However, it works well. I have stood on it to load it and it has supported me (205lbs), the tire w/rim, 40lbs of gas and two large North Face Camping bags (est 85lbs). The most I have had on it while driving was est. 160-170lbs and the only thing that happened was the mounts from the drop in rack slid a little on the factory rack. And that was driving on 60KM of Congolese dirt roads, which are the equal to trail driving in the states. Since then I put truck topper tape between the factory rack and the drop in rack, no squeaks, no sliding.
The small compartment off of the back is for the jerry can. I also welded two loops on there so I could use one ratched strap to hold it down (one side is off-set a little for the jerry can nozzel).
Let me know if you have any other questions.
Name:	Comp IMG_2374.JPG
ID:	9251   Click image for larger version
Name:	Comp IMG_2380.JPG
ID:	9252   Click image for larger version
Name:	Comp IMG_2382.JPG
ID:	9253   Click image for larger version
Name:	Comp IMG_2384.JPG
ID:	9254   Click image for larger version
Name:	Comp IMG_2390.JPG
[x] PML
[x] 265/75R-16s
[x] Light bar w/KCs
[x] Idler Arm Brace
  #9
Old 12-27-2012, 04:19 PM
Tsunami's Avatar
Tsunami Tsunami is offline
Member: #25959
2011 S 4x4 Xterra
Tsunami is on a distinguished road
I just got my Yakima Loadwarrior basket and the spare tire holder for about $350. I am very pleased with it. I plan on adding lights and shovel/axe carrier onto the basket, its pretty heavy duty as well.
2011 Nissan Xterra S 4x4...off road here I come!!
