Transmission problems - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Offroad Modifications 2nd gen (05+) > Offroad Drivetrain
Old 12-14-2012, 08:44 AM
Wrx19687 Wrx19687 is offline
Member: #37374
2010 Xterra
Wrx19687 is on a distinguished road
I have a 2010 xterra offroad with automatic trans. I've done some searching and I see a lot of 05 xterra had the trans cooler go bad. Does this trans cooler go bad in the 2010 model also. The problem I have is when you put it in reverse or drive it hesitates for a second then it goes into the gear. I checked the trans fluid it's nice and clear. No milky look to it at all. The vehicle has 63000 miles on it.
Old 12-17-2012, 09:03 AM
Member: #37374
2010 Xterra
Anybody know what I can do to fix this problem. I checked the radiator cap and it looks good to. Checked both the reservoir and the radiator. Does not do it all the time. For instance this morning it was around 50 degrees. I got in it. Let it warm up a bit stuck in reverse. It went in like it suppose to. I went to the shop to open everything up and to wait for my daughters bus to come. When I went out to take her to the bus I stuck it in reverse it hesitated. You would think it would of done it this morning when it was cold then now. Any help I really don't have the money to take it to the dealer.
Old 12-17-2012, 09:08 AM
maillet282's Avatar
maillet282 maillet282 is offline
Seasoned
Member: #28826
2009 OR Xterra
maillet282 is on a distinguished road
Was the trans ever serviced ( By the dealership or anybody els?) second did you check the fluid level on the trans dipstick?
build thread:
My 09 Xterra
Old 12-17-2012, 11:13 AM
Member: #37374
2010 Xterra
That I know of trans was never service. The fluid level was at the full mark. I just recently purchased the vehicle. It had 61000 when I purchased it. Carfax was clean.
Old 12-17-2012, 11:36 AM
dezurtrat's Avatar
dezurtrat dezurtrat is online now
Mindless Modding Moderator
Member: #2413
2008 Xterra
dezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of light
Are you by chance parked on a hill, even slightly? The newer Xterra's have hill assist and they actually hold the breaks using the ABS system until you have time to get your foot from the brake pedal to the accelerator pedal so sometimes you get this slight hesitation. Just an idea.
Old 12-17-2012, 12:46 PM
Member: #37374
2010 Xterra
Hey dezurtrat I am on a slight hill when parked. I will keep a look out for that. That could be my case. I hope it is.
Old 01-07-2013, 06:46 PM
ryandavenport's Avatar
ryandavenport ryandavenport is online now
Professional
Member: #15330
2007 Xterra
ryandavenport has a spectacular aura about themryandavenport has a spectacular aura about themryandavenport has a spectacular aura about them
I would be willing to bet that is what you are running into. You shouldn't be running into any transmission issues. Regardless, it wouldn't be bad to flush the fluid at that mileage and refill with all new Nissan Matic S.
2007 Xterra S 4x4
Wheels, Tires, and Suspension
285-75 R16 BFG AT-KO, Pro-4X Wheels, 2" OME Lift
NXRocks Skids, TAG Rear Bumper, White-Knuckle Off-Road Rock Sliders
Exterior
Xoskel Bumper Mount Bracket, Blacked out Emblems, Weathertech Vent Visors, FOURTREKS Hi-Lift Mount, Wilson1000 CB Antenna
Pioneer AVHP3200DVD, Midland CB, Compass Mirror, Nissan All-Weather Floor Mats, Nissan Carpeted Cargo Mat
  #8
Old 01-07-2013, 06:50 PM
Member: #37374
2010 Xterra
Thanks ryandavenport
  #9
Old 01-07-2013, 07:02 PM
Professional
Member: #15330
2007 Xterra
No problem! If you do it yourself, make sure to have 12 qts on hand to do the flush. Thats about how much it will take before you see good transmission fluid.
2007 Xterra S 4x4
Exterior
