copper spraying the headgasket or not?? - Nissan Xterra Forum: Xterra Forums
Old 12-13-2012, 02:26 PM
gogogsr gogogsr is offline
Member: #29030
gogogsr is on a distinguished road
Hey guys, i'm wondering if i should use copper spray gasket or the #1 form-a-gasket on the headgasket or just use it dry as is? Block deck and cylinder head surfaces will only be cleaned, not machined.
thanks
Old 12-13-2012, 02:30 PM
intender's Avatar
intender intender is offline
Member: #30982
I wouldnt apply anything to the head gasket unless the fsm calls for it. It seems to me that it would just be a weak point for a leak to occur.
Why not get the head machined. It usually cost $100 or less for a good machine shop to do it.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 12-13-2012, 02:43 PM
Member: #29030
if it's within specs i wont touch it, i need my truck asap
Old 12-13-2012, 02:45 PM
Member: #29030
if it's within specs i won't touch it, i need my truck asap
Old 12-13-2012, 02:59 PM
eGoCeNTRoNiX eGoCeNTRoNiX is offline
Member: #32902
eGoCeNTRoNiX is on a distinguished road
Just go bare.. No need for the copper..
Old 12-13-2012, 03:43 PM
ShiftingSkys's Avatar
Member: #16608
X3 on no copper. If Nissan did not specify that you should do it then you should not do it.
2002 Nissan Xterra
Lifted and Ready to Roll!
Old 12-13-2012, 03:47 PM
Member: #29030
intake manifold gasket???
  #8
Old 12-13-2012, 04:24 PM
muadeeb muadeeb is offline
Banned
Member: #29357
Same: No liquid gasket called for so don't use it
  #9
Old 12-16-2012, 07:21 AM
Member: #29030
do you guys think that this scratch could mean trouble, my finger nail catch it pretty good
  #10
Old 12-16-2012, 02:09 PM
Member: #16608
Definantly. If your nail catches it then hell yeah. That right there is its own feeler gauge. Scratches like that are why you have it resurfaced. (other than it being warped)
I say if your going through the work to rebuild the motor spend the money to do it right...
2002 Nissan Xterra
