Dome Light Help - Nissan Xterra Forum: Xterra Forums
Old 12-12-2012, 12:09 PM
thanks28's Avatar
thanks28 thanks28 is offline
Member: #22923
thanks28 is on a distinguished road
Dome Light Help
My dome lights don't seem to work. Which fuse is it? I don't think it is the fuse though because my front map lights work.
Is there another fuse idk about?
"Only the Best"
2002 Xterra SE 4x4 Solar Yellow
  • Cherry Bomb Glasspack Muffler
  • Concept Customs Lightbar w/ Pro Comp Long Ranges
  • Tinted All Windows to Match
  • Full Kenwood audio from Deck to Subs
  • Front Off Road Lights
  • PML
  • Custom Built Rock Sliders w/ Bedliner
  • Roof Basket w/ Spare Tire
  • DIY Hi-Lift Mount
  • 18" Rockstar XD wheels with 33"x12.50 Toyo Open Country Tires
Big Bird Build
Old 12-12-2012, 01:15 PM
muadeeb muadeeb is offline
Banned
Member: #29357
28 (7.5A); same fuse for both dome lamps. Map lights are 26.
Old 12-12-2012, 03:27 PM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
Did you check the bulb?
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 12-12-2012, 06:13 PM
intender's Avatar
intender intender is offline
Member: #30982
mine constantly burns out. If I manage to get 2 or 3 months without the light burning out I would be really impressed. i buy them 4 at a time. Even then I feel like I am constantly buying these stupid things.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 12-12-2012, 08:52 PM
Banned
Member: #29357
He's swapped the bulbs, front to back and the problem stays at the front fixture
Old 12-12-2012, 08:54 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
If the fuses are intact get a test light and see if you have 12 volt at the connection and start working you way towards the power source origin.
Old 12-13-2012, 12:04 AM
thanks28's Avatar
Member: #22923
I got a meter and checked and only the hatch light is showing 12v. The other dome light isn't reading anything. This seems weird considering that when peeking under the headliner they are connected to the same harness.
I think I am just going to say forget the dome light and run a separte fused power wire up to that spot and mount a flip down dvd player.
Think I could splice into the rear dome's power and run it to that spot??
"Only the Best"
  • PML
  • DIY Hi-Lift Mount
Big Bird Build
