Shudder at shifting around 45-50mph - Nissan Xterra Forum: Xterra Forums
Old 12-11-2012, 03:57 PM
uncletwodogs's Avatar
uncletwodogs uncletwodogs is offline
Member: #5213
uncletwodogs is on a distinguished road
I've got an 03' 4x4, V6 automatic. A few months ago I noticed a shudder/vibration when the transmission is shifting from (I assume) 4th or 5th gear. The AT level is ok on the dipstick and I've noticed no leakage. Also, I replaced the U-joints which didn't fix the problem.
I found info in the forums that suggested it may be cross contamination of coolant and AT fluid. My coolant in the reservoir looks fine. I also found where some folks will just drain the fluid at the pan twice, instead of dropping the pan and replacing the filter and gasket.
Can I get some input or an update on this? For those who drained and replaced the fluid, did it stop the shifting issues?
2003 Xterra SE 4x4 Canteen
NISMO CAI, Bilsteins, Calmini IAB, Optima Yellow Top,
Cobra 75wx, NGK Platinum Plugs, NGK Wires, Royal Purple Oil
2004 Xterra SE 4x4 Silver Ice (Totaled body=next project)
Old 12-11-2012, 09:10 PM
muadeeb muadeeb is offline
Banned
Member: #29357
A few corrections:
1st Gens have a 4 spd A/T.
The coolant/ATF mixing problem (SMOD) is more of a 2nd gen problem. I'm not saying it'll never happen with a 1st, but is very, very, VERY unlikely based on the number of vehicles on the road with the problem.
You haven't mentioned if the fluid has been changed or not. A 2003 will likely be approaching 150K, and that long on factory fluid is too long. Fluid changing would be very high on my list at this point. It's a 9 qt system, and approx half will come out with each drain, but be prepared the first time with plenty -- refill with new the same volume that comes out. Drain and fill about a week apart for 4 or 5 times to make certain all the old is out.
Changing the filter is optional as it's more of a screen mesh than a foam or paper filter. Dropping the pan is the only way to clean the magnet, however.
Old 12-13-2012, 07:37 AM
Member: #5213
Thanks for clearing that up for me and I plan to change the fluid ASAP.
Old 12-13-2012, 09:39 PM
emmdock emmdock is offline
Member: #8630
emmdock is on a distinguished road
The vibration is the torque converter locking up while surrounded by fluid that's lost its friction modifiers. It happens at 43-47mph under light load once the transmission fluid is warm. It feels like a 5th gear, but it's not really a gear. I had the same thing - change the fluid twice because you only get like half out each time, and you'll be good. I did it 3 times for good measure. It was still cheaper than having a shop do it.
2002 Xterra XE 3.3 4x4 auto | JL 500/1v2 + 10W7 | Viper 5901 remote starter | Rear sway bar delete | Bilsteins all around | IAB | 2" DIY BL | KC HiLiTES on homemade roof bar | AC Shackles/PML | 33x12.5/15 Goodyear Wrangler MT/R with Kevlar on Cragar Soft 8s | Skid Row skids | Yakima Loadwarrior | Beginning of a build thread
Old 01-06-2013, 01:47 PM
robbtemp robbtemp is offline
Member: #17237
robbtemp is on a distinguished road
I have a 2001 with around 120K on it and just noticed this exact same problem. She doesn't get driven much anymore, maybe 2-4K a year. I'll start with the fluid changes as it's the original fluid. Thanks for the advice from the posters and to the OP for a good description of the problem!!
I'll report back results.
