S.a.s - Nissan Xterra Forum: Xterra Forums
Old 12-05-2012, 04:56 PM
andrewkoo andrewkoo is offline
AndrewKoo_
Member: #25966
andrewkoo is on a distinguished road
S.a.s
hey everyone, my name is andrew. i have been a member for a little over a year but i have never posted anything. i have a 2wd 2002 nissan xterra with a calmini 3" sl, a 2" bl, and I'm looking to do a solid axle swap. i am just wonder what kind of front axle i would need and was wondering if theres anything else i need other than the calmini kit?
Old 12-05-2012, 05:20 PM
emmdock emmdock is offline
Member: #8630
emmdock is on a distinguished road
You'll need a 4WD conversion, too. Not a simple swap, you might be best off finding a rear-ended totaled 4wd X to buy to swap all the parts if you are set on keeping your current X, instead of selling it and getting a 4wd.
2002 Xterra XE 3.3 4x4 auto | JL 500/1v2 + 10W7 | Viper 5901 remote starter | Rear sway bar delete | Bilsteins all around | IAB | 2" DIY BL | KC HiLiTES on homemade roof bar | AC Shackles/PML | 33x12.5/15 Goodyear Wrangler MT/R with Kevlar on Cragar Soft 8s | Skid Row skids | Yakima Loadwarrior | Beginning of a build thread
Old 12-05-2012, 06:25 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
If you intend to use the Calmini SAS kit at the minimum you would need a transfer case, 4x4 auto trans, and rear drive shaft from a donor Xterra I think. If you were to go that route I'd consider a Calmini SYE and a custom rear drive shaft from say Tom Woods.
Old 12-06-2012, 01:49 PM
yellowbug's Avatar
yellowbug yellowbug is offline
Member: #27174
01 Xterra
yellowbug will become famous soon enoughyellowbug will become famous soon enough
x3 like everyone else has said inorder for your sas to work you would need the transfer case rear and front drive shaft donor axle.
As for your question on what axle to get all depends on you. If you want it to be the similar width as what you have now look for a D44 out of a jeep wagooner. If you want a full width axle then its up to you. I am putting D60's front and rear on mine soon. If you do full width up front you might want todo it in the rear also. What ever you do get a drives side drop front axle or you would have wasted your money.
