High pitched squealing sound - Nissan Xterra Forum: Xterra Forums
Old 12-05-2012, 01:29 PM
proudxterraowner's Avatar
proudxterraowner proudxterraowner is offline
Member: #33663
2003 XE V6 Xterra
proudxterraowner is on a distinguished road
I just noticed when I was leaving school earlier that there is a low but very high pitched squeal coming front the front right tire area it really only does it when I'm turning left but not right. It sounds as if my break pads may be extremely worn and are like barely touching the disc like maybe metal against metal. Any ideas??
Hunter
Sent from my DROID RAZR HD using AutoGuide.Com Free App
I'm Hunter!
03 XE 4X2
(X) Remove damage multiplier(grille guard), steps, n mudflaps
(X) K/N drop in
( ) bull bar
( ) better set of allterrains
You want to race me in a car? Sure! Let's get off the road. Mine can go more places!
Old 12-05-2012, 01:50 PM
intender's Avatar
intender intender is offline
Member: #30982
could be the brakes. Mine started off more or less like that. after a couple weeks it was a constant loud squeal. Wheel bearings and cv joints can make similar noises, but they should be more constant. I would say jack up the front and see if you have any play in either of the front wheels. If not it doesnt rule out wheel bearings, but I would focus more on brakes.
I assume you dont have any vibrations when driving.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 12-05-2012, 02:00 PM
Member: #33663
2003 XE V6 Xterra
Alright thanks hopefully I can do this sometime this weekend
I'm Hunter!
03 XE 4X2
(X) K/N drop in
( ) bull bar
Old 12-05-2012, 04:24 PM
intender's Avatar
Member: #30982
The only thing thats really a pain with the brakes is compressing the pistons. The x has 2 pistons on each caliper and I couldnt get them to compress together so I would compress one as far as I could and then move the clamp and compress the other side. I had to move it back and forth a couple of times before it was fully compressed. Still not hard, but consumes a bit more time than I am used to. Use the old break pad and a C clamp to compress them. Open your break fluid reservoir and put a couple of towels around it to catch any fluid that might come out. It shouldnt be an issue unless you have added fluid at some point. A lot of people do it thinking they need to top off the fluid, but its a sealed system so if your fluid is low you either have a leak or your pads need changed.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 12-05-2012, 10:05 PM
phrog man's Avatar
phrog man phrog man is offline
Chrome can go to hell
Member: #4157
phrog man will become famous soon enough
Check the power steering belt. Then the brakes. Take a pic of the brakes when you have the wheel off. I can tell if they need changing.
2004 BLACK X-AUTO
Build Thread
Old 12-07-2012, 07:11 PM
Member: #33663
2003 XE V6 Xterra
Is there some way I can upload a vid from my phone via the app? I got a vid of what it sounds like
I'm Hunter!
03 XE 4X2
(X) K/N drop in
( ) bull bar
Old 12-07-2012, 07:16 PM
intender's Avatar
Member: #30982
get a photobucket account and you can upload vids and images with the mobile app. and then post the link for the vid here.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
  #8
Old 12-07-2012, 08:24 PM
Member: #33663
2003 XE V6 Xterra
Ugh!!!
http://s1275.photobucket.com/albums/...psef8d021c.mp4
I'm Hunter!
03 XE 4X2
(X) K/N drop in
( ) bull bar
  #9
Old 12-07-2012, 08:33 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Pull the wheels and check the pads that sounds like extremely worn out pads.
  #10
Old 12-07-2012, 08:44 PM
Member: #33663
2003 XE V6 Xterra
Also I didn't have the brake pressed down hopefully it is the brakes
I'm Hunter!
03 XE 4X2
(X) K/N drop in
( ) bull bar
