noob question about rims - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Tech Talk > Modification Questions
Old 12-05-2012, 10:25 AM
dannybiel dannybiel is offline
Member: #35385
2012 Xterra
dannybiel is on a distinguished road
So I recently came across a good deal on craigslist. I found a set of 4 18" rockstar rims flat black with Bridgestone dueler tires, everything only has 1200 miles on them and they're in perfect shape. The deal I worked out is wheels and tires for only 400$. My question is will they fit on a 2012 base model xterra. I know nothing about rim size of my car but the rims on craigslist are 6 lug with a 5.00 offset. will these fit on my truck? Any help would be appreciated
Old 12-05-2012, 01:29 PM
iwashmycar's Avatar
iwashmycar iwashmycar is offline
Member: #31171
2003 Xterra
iwashmycar is on a distinguished road
Depends on the bolt circle. You have 6x4.5" (6x114.3mm) 5" backspacing is not bad. They'll stick out a little, but it is going to depend on tire size for rubbing or no rubbing!
-Adam
2003 Nissan Xterra XE 2WD AT
2007 (O|TOYOTA|O) FJ Cruiser 4WD AT
