03 xterra running rough p0300 & p0328 - Nissan Xterra Forum: Xterra Forums
Old 12-04-2012, 02:58 PM
Cookiemanpf Cookiemanpf is offline
Member: #12773
2003 Xterra
Cookiemanpf is on a distinguished road
Hey guys I'm having a problem with my 03 xterra , it has the v6 3.3,
It continues to run really rough and almost stall when motors warm .. So far I've replaced the plugs , wires , distributor, knock sensor , yet still have the problem .. I'm also noticing some black soot under the truck coming from the exhaust .. The codes were p0300 & p0328 . Which is misfire and knock sensor .. I did notice when I replaced the plugs that the #6 plug in the back was black colored , the rest of the plugs were caramel colored , like they should be ..
I'm thinking maybe a coil is bad ? Are there 6 separate coils for each cylinder ?
Old 12-05-2012, 06:43 AM
Member: #12773
2003 Xterra
Smile Help
Maybe a faulty fuel injector ? How do I test the fuel injectors ? Cause I did get a code last week from auto zone that said misfire on # 6 cylinder , and that was the plug that was black , the rest of the plugs were normal , I replaced that #6 plug , it ran better for a few hours , then threw the p0300 & p0328 code again ..
Got me stumped .. C'mon guys , whatcha think ?
Old 12-05-2012, 10:01 AM
SamsXE's Avatar
SamsXE SamsXE is offline
Member: #33065
Yeah sounds like the injector. I would pull it and see what kind of buildup you have. If it were a distributor more than likely there would be issues on other cylinders. And 1 cylinder firing out of order due to a "stuck" injector can cause stalling. They are relatively cheap.
Do you have any exhaust leaks?
My Build Thread:
Old 12-05-2012, 11:41 AM
Member: #12773
2003 Xterra
Thanks
No exhaust leaks , I just sea foamed the motor and put some in fuel tank , hope that might help the injector .. But what I'm wondering is , if that #6 spark plug was black , wouldn't that mean there's a rich condition ? Like it's getting too much fuel ?
Old 12-05-2012, 12:12 PM
SamsXE's Avatar
Member: #33065
Think of the injector as a valve. If it is all gummed up or has debris in it, it may create a condition where the injector is sticking open longer than usual. Seafoam might help but if you want...try taking the injector out and spraying the end with carb cleaner. Should remove varnish...im not sure that will cure the issue but its worth a shot.
Thats what I would do anyway...
My Build Thread:
