Brake Booster for 2000 - Nissan Xterra Forum: Xterra Forums
Old 12-01-2012, 08:49 AM
fdny37 fdny37 is offline
Member: #37685
fdny37 is on a distinguished road
Hi, this is my first post. My brother has a 2000 Xterra and his brake pedal is hard. I told him to check the one way valve for proper operation. My main question is this.
Is it a PITA to change out the booster? I looked at it and it seems that there may be no way to remove and replace without the master cylinder being completely removed. Am I correct in this assumption? I would just like to know this before going in head first to remove. Any help would be greatly appreciated.
BTW, I did a search and couldn't find any detailed info for remove and replace.
Old 12-01-2012, 02:34 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
The factory service manuals will have that information and can be found here. You are looking for section BR and the booster removal can be found on page 16. You will have to remove the master cylinder.
