Engine Codes P1143,P0134,P0328 - Nissan Xterra Forum
post #1 of 30 Old 11-29-2012, 11:04 PM Thread Starter
kdog125
kdog125 is on a distinguished road
Hey everyone, I just got checked out at autozone and they ran these codes for a CEL on. Light has been on a few weeks. Also came on a few months ago but didnt last too long. He cleared the codes and will see if it comes back. Need inspection done ASAP. Anyone have any info on these codes? I read on the knock sensor code and seems like i should just ignore it. I have a 2002 SE 4x4 not SC. Truck seems to be running perfectly fine. No knocking sounds at all, consistent oil changes every 3k miles. Truck has like 138k miles on it. No rough idling or anything. Does anyone have any info on the other codes? I believe they are o2 sensors? Thank a lot.
kdog125 is offline
post #2 of 30 Old 11-29-2012, 11:13 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
All the codes can be found in the EC (engine control) section of the factory service manual. Search for each individual code and it will show you the possible causes and how to diagnose the problem.
RacerXXL is offline
2000 XE Xterra
post #3 of 30 Old 11-30-2012, 08:53 AM
ShiftingSkys
ShiftingSkys's Avatar
Quoted: 1 Post(s)
Possible causes of the code P1143
- Faulty Front Heated Oxygen Sensor Bank 1
- Intake air leaks
- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Fuel pressure
- Injectors
If there are no intake air leaks, the most likely cause of the P1143 code is the front O2 sensor bank 1.
P0134
Replacing the O2 Sensor 1 usually takes care of the problem
Help with this
When is the code detected?
The voltage from the sensor is constantly approx. 0.3V
The third is Knock sensor. I would just leave that alone. More often than not with that code replacing that sensor fixes it.
OBD-ll Codes.com
2002 Nissan Xterra
Lifted and Ready to Roll!
ShiftingSkys is offline
post #4 of 30 Old 11-30-2012, 02:23 PM Thread Starter
kdog125
Thanks for the info. Just wanna make sure, the oxygen sensor one is on the passenger side, highest up and can be seen easily seem? Wasn't able to upload a picture sorry
kdog125 is offline
post #5 of 30 Old 11-30-2012, 02:52 PM
muadeeb
Banned
Yep, that's Bank 1, Sensor 1. When you pull it, the bung may come out of the exhaust too.
muadeeb is offline
post #6 of 30 Old 11-30-2012, 03:42 PM Thread Starter
kdog125
Don't I need that bung to come out so I can put the new sensor into that bung and I put that whole piece (sensor and bung) back into its original spot? Thanks again for all the help
kdog125 is offline
post #7 of 30 Old 11-30-2012, 04:09 PM
muadeeb
Banned
Both are threaded, so if it stays in, great. If it comes out, fine.
muadeeb is offline
post #8 of 30 Old 11-30-2012, 11:49 PM Thread Starter
kdog125
Hey guys. I picked up the oxygen sensor (part #13420). I'm just confused on the location of this sensor under the hood. It's the oxygen sensor 1, bank 1 that needs to be changed. I've read its the one located on the passenger side of the engine bay and lays on top of the exhaust manifold I believe (pics attached) and be easily worked upon. However in the diagram attached, it seems like sensor one bank one is on the opposite side (driver side). Any clarity would be very appreciated.
ID:	9183   Click image for larger version
ID:	9184   Click image for larger version
ID:	9185   Click image for larger version
kdog125 is offline
post #9 of 30 Old 12-01-2012, 12:05 AM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
The view in that diagram you have is from the rear, flywheel end, of the engine so it is on the PS. Should be the one that is screwed into the Cat.
Have you run through the diagnostic to find what is causing the code?
RacerXXL is offline
2000 XE Xterra
post #10 of 30 Old 12-01-2012, 12:18 AM Thread Starter
kdog125
Hmm i'm still confused by what you said. I just got those codes when I got it read at autozone b/c my CEL was lit for a few weeks. I've noticed excessive exhaust smoke and definitely have noticed high fuel consumption. So i figured i would replace sensor one bank one and hope that takes care of the problem/CEL light from coming back on...So is the picture I took of the sensor the correct sensor to be changed? sensor one bank one?
kdog125 is offline
