too much oil in X? - Nissan Xterra Forum: Xterra Forums
Old 11-28-2012, 06:54 AM
black black is offline
Member: #6977
2003 Xterra
black is on a distinguished road
too much oil in X?
Driving into work today i get a check engine light
its an 03 X with 170K on the clock.
i'm a little obsessive with this so I havent had a chance to pull a code.
However 11 days ago? I put in a quart of oil as the oil was down pretty low.
after which when i drove it the day after i smelled some oil but it dissapeared very quickly.
Either way I put about 200 miles on it since then , now the check engine light is on
I figure I'll pull the code at lunch at an auto store, go home drain the oil and put in some new oil , hopefully clear the code by disconnecting the battery. and hopefully that will be that
is this reasonable? or could I have cause a larger issue by putting too much oil? that simply draining and refillling wont cure?
again I donthave the codes pulled yet so I'm just extrapolating here
Old 11-28-2012, 09:13 AM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
Too much oil won't set the light. Find out why the light is on first.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 11-28-2012, 09:19 AM
Member: #6977
2003 Xterra
sounds good shoul dhave something in 2 hours hopefully
thanks
Old 11-28-2012, 09:35 AM
intender's Avatar
intender intender is offline
Member: #30982
dont make it a habit of putting too much oil in your xterra unless you want to replace the rear main seal. never done it myself, but I hear its not an easy fix.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 11-28-2012, 07:25 PM
ShiftingSkys's Avatar
Member: #16608
X2 on the proper filling of the X. The X's Rear main seal usually is the first to blow when the engine has too much oil. I have never heard of oil setting a CEL so Let us know what code you get so we can get it back on the road for you.
2002 Nissan Xterra
Lifted and Ready to Roll!
