Blown headgasket or intake manifold gasket?? - Nissan Xterra Forum: Xterra Forums
Old 11-27-2012, 07:48 AM
gogogsr gogogsr is offline
Member: #29030
gogogsr is on a distinguished road
Hey guys, i recently did my oil change and noticed there was a small amount of milky oil on top of the pan (maybe a tennis ball size) and the rest of the oil was clean, the oil cap and dipstick were also clean. I noticed i had to fill up the radiator but i dont know if it was always missing coolant or if it happened recently. There was thick white smoke when i was giving it throttle. I did a compression test and got 175 psi in each cylinder. I had to unbolt the upper intake manifold to get to cylinder number 6. I tought maybe the headgasket as gone bad only recently, which would explain the little amount of milky oil and the high compression. So i decided to do a leak down test with a custom tool (https://www.youtube.com/watch?v=7UcOn8OEt0Y).
I did test on number 1, align last left notch of crank pulley with water pump arrow on top of the pulley and did the test (at cold). The air was rushing through the intake manifold port so i guess i have bad timing or bad valves but it's weird because the compression test was fine. I also noticed prestone was leaking from the rear passenger side hose of the upper intake manifold (i had to cut them to remove the plenum, i think its IACV and AAC). Now i'm waiting to do the other cylinders. I would like to know if i got the good way to find TDC and if it is normal to have good compression and a bad headgsket. I also think it might be the intake manifold to head gasket??
what you guys think
Thanks
Old 11-27-2012, 06:05 PM
Member: #29030
Ok guys, so i just did the leakdown test and here are the results:
The tool i used is similar to this one (custom made):
Pressure was set on 50 psi on the left gauge, after plugging to the hose pressure drop to 40 and the right gauge reading was:
cyl : 31 =22%
cyl2: 36 =10%
cyl3: 35 =12%
cyl4: 35 =12%
cyl5: 35 =12%
cyl6: 32 =20%
I did notice a crackle sound on cylinder 4 and 6, kind of a metal gasket crushing. No bubbles in rad, no intake leak, no exhaust leak, just crankcase blow by, which considering the truck has 200,000 km on it seems fair. Remember that the compression was 170 across the board.
I'm thinking it could be the intake manifold lower gasket, what you guys think??
thanks guys
Old 11-27-2012, 10:50 PM
Member: #29030
what do you think of this hypothesis: Intake manifold is leaking from its water port directly into the runner, which then drop into the combustion chamber, hence the white smoke. Some of it pass through the rings hence contamining the oil just a bit.
What you think???
Old 12-02-2012, 03:14 PM
Member: #29030
no leak in radiator when doing leak down test, no lost of pressure when doing cooling system pressure test, truck runs good, compression is good. Is there another test i can do to try to find the culprit of burning coolant?
thanks guys, i'm this close to bringing it to the garage if i annot pin point the problem
Old 12-09-2012, 12:42 PM
Member: #29030
ok, what you guys think:
leakdown test, passed
compression test, passed
block tester, passed
milky oil
Cracked head??? I'm sure it is not the headgasket since the leak test and block tester test were not showing any signs of bad headgasket, what else could i try?
Old 12-10-2012, 04:33 PM
Member: #29030
does that look like a bad intake manifold gasket coolant leak??
thx
[IMG][/IMG]
[IMG][/IMG]
Old 12-11-2012, 07:28 AM
SamsXE's Avatar
SamsXE SamsXE is offline
Member: #33065
Looks like you have this one thoroughly worked out haha! Nice job! Replace the gasket and clean out the Intake and you shlould be good to go.
My Build Thread:
  #8
Old 12-11-2012, 09:27 AM
Member: #29030
I'll change the headgasket since i'm all the way there
  #9
Old 12-11-2012, 09:31 AM
muadeeb muadeeb is offline
Banned
Member: #29357
Might as well do the knock sensor too
  #10
Old 12-11-2012, 11:37 AM
Member: #29030
is it something that is prone to failure??
