Turn Key...and...Nothing! Loose battery connection - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Tech Talk > Repair Questions > It Won't Start!!!
Old 11-26-2012, 05:29 PM
robcarync's Avatar
Member: #33023
My ground battery cable has a loose connection around the battery terminal. The clamp is screwed in as tight as it can go, but I can still grab the clamp and slip it off of the battery post. This loose connection, now that cold weather has come into play, means that when I go out in the morning and turn they key, nothing happens. If I pop the hood, wiggle the ground clamp a little bit, and turn they key, it starts fine.
Has anyone else ever experienced this? Either the battery post shrinks or the clamp got bigger. I'm assuming the cold weather has caused some sort of material contraction and thus the weak connection...
Obviously, I just told you what the problem is...but I am curious if anyone has had this before and what you did to fix it...seems the stock battery clamps should be able to work...
2004 Xterra 4X4
To Do
Building my X
Old 11-26-2012, 06:08 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Saying the OEM battery cable ends, especially the ground, are crap would be generous. It's on my list to replace them but the OEM cable ends are a really, really bad design.
Old 11-26-2012, 06:16 PM
jasona801 jasona801 is offline
Member: #37356
jasona801 is on a distinguished road
Loosen the clamp, bend a penny on the same radius as the clamp, put the penny in between the post and the clamp. Temporary fix that works long term if needed.
Old 11-26-2012, 06:24 PM
intender's Avatar
intender intender is online now
Member: #30982
if you go to advance auto or somewhere like that they sell these lead things that look like a thimble that goes over your battery terminal to make it bigger. I had to put one on the xterra last year. It was only about a dollar or so and has done the job so far.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 11-26-2012, 08:02 PM
cbxterra cbxterra is offline
Member: #18847
new battery clamp. replaced mine at the evil empire [Wal Mart]. Any auto parts store too.
Old 11-26-2012, 09:10 PM
ShiftingSkys's Avatar
Member: #16608
Bottle caps Lol jk. On a more serious note though the best solution is to just replace the battery cables.
2002 Nissan Xterra
Lifted and Ready to Roll!
Old 11-26-2012, 09:45 PM
robcarync's Avatar
Member: #33023
good to know guys...thanks! I will pick up a new clamp this week!
2004 Xterra 4X4
To Do
Building my X
  #8
Old 11-26-2012, 11:54 PM
intender's Avatar
Member: #30982
My first car was a 1982 ford exp. The positive battery cable on it would fall off while I was driving if I went to fast around curves(least of that cars problems). I broke the tab off the top of a can of dr. pepper and wedged it in and tightened it up. After I got a new car my dad drove it for a couple of years like that and never had any problems. And unlike a penny i wont cause corrosion on the terminal.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
  #9
Old 11-27-2012, 12:16 AM
Member: #37356
Lol yeah I've honestly had a penny in the clamp on my spec v for a year and a half no problems lol just haven't gotten around to changing the clamp
  #10
Old 11-27-2012, 08:42 AM
robcarync's Avatar
Member: #33023
Good call on the can tab...I have a few miller lites in the fridge....hmmmmm
2004 Xterra 4X4
To Do
Building my X
