Question--- - Nissan Xterra Forum
post #1 of 19 Old 11-25-2012, 11:05 PM Thread Starter
c23k
c23k is on a distinguished road
Question---
A 2000 xterra has a broken timing belt, and is it a good buy? There is said to be nothing wrong with the valves, or head, or anything of that nature just a simple timing belt. It has 180K mileage. Is this a good deal to go after or is it too much of a hassle? Any and all comments will be appreciated! Thank you.
c23k is offline
post #2 of 19 Old 11-25-2012, 11:14 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
How much do they want? How exactly can they guarantee there is no top end damage? Did they pull the heads? Do they guarantee, in writing, that if you put on a timing belt it will be fine?
RacerXXL is offline
2000 XE Xterra
post #3 of 19 Old 11-25-2012, 11:22 PM Thread Starter
c23k
They want 2500 obo i offered 2000, they are getting back to me to know if it goes.
They said they were not driving far enough and or fast enough for it to damage any top end. They were doing 25 when it broke and not even a block from their house. All what I have been told by seller. I can contact the seller and see if they will do that. I was going to have a certified mechanic go with me if and when I got it.
c23k is offline
post #4 of 19 Old 11-25-2012, 11:38 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
Depending on the condition of the rest of the vehicle the price you offered sounds ok but they can bend/break/damage valves/pistons at any speed when the belt breaks. So the fact it broke at 25mph is really not relevant and you are taking the same risk as buying any VG33E engine with a broken belt. Some make it just fine and some do not. Good luck.
RacerXXL is offline
2000 XE Xterra
post #5 of 19 Old 11-25-2012, 11:45 PM Thread Starter
c23k
The rest of the vehicle is really good shape,newer tires good tread life left. Green in color 5 speed manual really good looking xterra......
And ok ,should I have a mechanic check it out prior to purchase to make sure is just a timing belt it needs? Or anyway I can tell ?
Thank you
c23k is offline
post #6 of 19 Old 11-26-2012, 12:10 AM
xtacular
Spaz
xtacular's Avatar
Quoted: 74 Post(s)
There's no way to tell besides putting a new belt on and running it, or pulling the heads, both of which require a bit of labor. Is it 4wd I'm curious?
2002 Super Black 5 Speed 4x4
xtacular is offline
post #7 of 19 Old 11-26-2012, 06:18 AM Thread Starter
c23k
Yes 4x4
c23k is offline
post #8 of 19 Old 11-26-2012, 06:38 AM
Tarditi
Tarditi's Avatar
Quoted: 7 Post(s)
2006 Xterra
IMHO - it is a black box right now... could just need a timing belt, could need a rebuild.
Frankly, amount of wear on the tires would be a minor concern right now - do you have budget to replace the engine if it's that bad?
This is a gamble but don't play unless you can afford to be on the losing end.
Would this be your 2nd or 3rd vehicle? Can you manage with it in the shop for several weeks?
Figure the cost of a full engine rebuild + the $2000 purchase price + any other items that needed attention. If the vehicle was that pristine, I'm not sure I would let it go if it "just needed a belt" - even considering the labor involved.
Dustin Tarditi
Raleigh, NC
2006 Granite S
Tarditi is offline
2006 Xterra
post #9 of 19 Old 11-26-2012, 09:27 AM
Xterra Mike
Silver Submarine
Xterra Mike's Avatar
Quoted: 14 Post(s)
2001 SE Xterra
Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough
Garage
$2k is a good deal if its just the "timing belt" and the rest of the truck is in good condition. There is no way to tell if the valves are bent till you throw a new belt on there and start it up. A good mechanic can change a belt in about 2-3 hours and the belt is not expensive. Chances are the motor is ok but are you willing to take that chance?
Xterra Mike is offline
2001 SE Xterra
post #10 of 19 Old 11-26-2012, 09:38 AM Thread Starter
c23k
Ok so what are the signs that they are bent ?
c23k is offline
