Steering Problems... - Nissan Xterra Forum: Xterra Forums
Old 11-25-2012, 07:25 PM
3stars1sun's Avatar
3stars1sun 3stars1sun is offline
Member: #18204
3stars1sun is on a distinguished road
Hi guys, recently I went on a one month vacation. When I got back and drove it I noticed something, when Im trying to park and steer the wheel on either direction I hear a squeak... checked under the hood and a friend says it's the "steering pump try putting wd40"..... now before I do that I wanna hear it from fellow Xterra owners...
Where should I start looking? Im trying to avoid going to the dealership...
Thanx in advance
other problems I noticed:
1. When I start the X even at -0c temp the Engine temp is at "H"
2. Outside temp reading is inaccurate by 2c
2004 XterraSe
Old 11-25-2012, 11:01 PM
xtacular's Avatar
xtacular xtacular is offline
Member: #13879
Need more info- when does it happen specifically, where does it sound like it's coming from, and what type of a sound is it?
2002 Super Black 5 Speed 4x4
Shovel Mount
Old 11-26-2012, 06:44 AM
Xterror04's Avatar
Xterror04 Xterror04 is offline
Member: #8609
Xterror04 is a jewel in the roughXterror04 is a jewel in the roughXterror04 is a jewel in the roughXterror04 is a jewel in the rough
It could be the idler arm, usually the power steering pump makes more of a moaning groaning noise
Build Thread
Old 12-05-2012, 01:44 AM
tajturner tajturner is offline
Member: #37608
tajturner is on a distinguished road
I'm getting a similar whine when I turn right or left. Kinda like a "waaaaa" sound. I get a few seconds of a squeak when I start up. I put some belt dressing on yesterday but didn't help. I did put the dressing on with the motor off. Tried it with the motor on and it just blew back into my face.
So is this my power steering?
Old 12-07-2012, 09:33 AM
Member: #37608
bump
Old 12-07-2012, 10:14 AM
Jermberg Jermberg is offline
Member: #37735
Jermberg is on a distinguished road
A noise like a waaaa like u describe is most likely a power steering pump either going bad or low fluid or being pushed to stopes, beltes usealy make a squealing noise and as far as I no belt dressing only cover up the noise for a bit if ur belt is making noise it eather needs to be replaced or titend if it is cracked or frayed it needs to be replaced.
Old 12-07-2012, 10:15 AM
Member: #37735
Sorry or that noise can mean air in the power steering as well
  #8
Old 12-08-2012, 11:03 PM
Member: #37608
If its air in the pump, how does one get the air out?
  #9
Old 12-09-2012, 06:52 AM
ShiftingSkys's Avatar
Member: #16608
You must bleed to power steering. Drain the PS but... AS YOU DRAIN ADD MORE do not let it get low. if it gets real low your adding more air. After you o that start the vehicle.
Turn the steering wheel to its stopping point Left...Right...Left...Right. Once again DO NOT LET THE RESEVOIR GET LOW! Now not only will you introduce air you will be running your pump dry if the reservoir empties.Keep going Left....Right...LeftUntil you are satisfied.
A high pitched squealing = Belt
Woawoawoa or waaaaaaa = Pump usually thats going bad or low on fluid. temperature problem is interesting ill look and see what I can think of. You would have gotten a code if the CTS was bad. (coolant temperature sensor)
2002 Nissan Xterra
Lifted and Ready to Roll!
  #10
Old 12-11-2012, 10:03 PM
Member: #37608
Thanks Shifting,
And with that added bit of information, I am now convinced that the power steering pump is going out. Does anyone here have any experience(s) with aftermarket power steering pumps? Recommended? Not recommended? Any particular brands better or worst than others?
Tags
nissan xterra, steering problems
