Head bolt, replace or not - Nissan Xterra Forum: Xterra Forums
Old 11-24-2012, 09:23 PM
gogogsr gogogsr is offline
Member: #29030
gogogsr is on a distinguished road
Hey guys,
I just did an oil change today and my oil was like a milkshake (coolant in it) so i'm planning on doing a cylinder head overhaul and was wondering if i can re-use the cylinder head bolts?
thanks guys
Old 11-24-2012, 09:35 PM
intender's Avatar
intender intender is online now
Member: #30982
usually head bolts have a thread that kind of stretches a bit when installed. they are installed under a pretty insane torque setting and you run a risk of stripping one out if you reuse them. thats not to say that if you did use them you would have trouble, but I personally wouldnt risk it.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 11-24-2012, 11:00 PM
birddog01 birddog01 is offline
Member: #34772
birddog01 is on a distinguished road
Torque to Yield.
You may get lucky with one re-use.
By "may" I mean won't.
Ever meet someone that accidentally bought a set of 35s?
They call me Birddog. Master of the Sawzall.
01 XE/SE
5 speed
Currently
PML
35x12.50x15 BFG A/T on Legos
De-Plastified and Blacked out
Old 11-25-2012, 08:51 AM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
Head bolts are not reusable. You must buy new ones.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 11-25-2012, 10:46 AM
Member: #29030
I will do a leak down test today just to validate, the oil was still good except for like 15% of it which was brownish milkshake color. Does it mean i'm still in the early phase, should i replace it right away?
Old 11-25-2012, 11:17 AM
Silver Submarine
Member: #2784
2001 SE Xterra
Replace your oil ASAP. You don't want to be running "dirty" oil through that motor. You are reducing the life every second its running with that oil in it.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
Fan Club:
Old 11-27-2012, 07:53 AM
Member: #29030
compression test was 175 across the board, can it still be a bad headgasket with such numbers???
  #8
Old 11-27-2012, 08:25 AM
Silver Submarine
Member: #2784
2001 SE Xterra
Are you loosing coolant?
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
Fan Club:
  #9
Old 11-27-2012, 08:34 AM
Member: #29030
i add half a liter a month ago, but i dont know if it was allready missing
check my other thread for all the details
http://www.clubxterra.org/forums/showthread.php?t=40048
  #10
Old 11-27-2012, 02:42 PM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
It may not be leaking in the cumbustion chambers, but if it looked like milkshake, antifreeze is getting into the lower end. This can come from many areas, including a cracked or warped head, failed head gasket or rot through the waterjacket. (often the heads)
Don't run it with the milkshake, it will trash the rod and main bearings.
Never reuse head bolts! ever!!!
Itsme
2000 X SE
