Sway Bar - Nissan Xterra Forum: Xterra Forums
Old 11-24-2012, 08:26 AM
Bofenkamp Bofenkamp is offline
Member: #36477
2003 Xterra
Bofenkamp is on a distinguished road
Sway Bar
Hey everyone. My 03 X has a broken rear sway bar mount. I know I have read in the forums before about people pulling the sway bar out, but I can't find any pro's or con's to removing it. I do go off the trail once and a while, but it spends most of it's time on pavement or gravel. Im leaning towards just pulling it off, but thought I'd see what everyone had to say first.
Old 11-24-2012, 09:26 AM
Roadwarrior's Avatar
Roadwarrior Roadwarrior is offline
Member: #7866
Roadwarrior is on a distinguished road
It is useless.. When you pull it off, you will never notice that it is gone.
Also it rubs against your passenger side shock and can break that. There is no reason to keep it, unless you are just sentimentally attached to something that is hurting your car.
-Tucker-
2004 XE aka.. Roadwarrior
Look, look, look.. its a build thread "Can I touch it?"
Old 11-24-2012, 09:31 AM
Member: #36477
2003 Xterra
no attachment, just didn't wanna do something that might mess up alignment or who knows what else. I'm no mechanic, but not scared of nuts and bolts. It'll be removed today, thanks for the reply!
Old 11-24-2012, 09:42 AM
birddog01 birddog01 is offline
Member: #34772
birddog01 is on a distinguished road
It took me about 4 hours to figure out why my Pass rear shock blew after sticking the "new" tires on and hitting a light trail.
The bar gets the Sawzall tomorrow. With the typical mods that we do to our rigs there's little need for it.
Old 11-24-2012, 11:23 AM
yellowbug's Avatar
yellowbug yellowbug is offline
Member: #27174
01 Xterra
yellowbug will become famous soon enoughyellowbug will become famous soon enough
The con is it can damage your rear shock while flexing.
The pro well there really isn't one.
It doesn't effect body roll dramatically. I won't notice a difference in it at all.
Old 11-24-2012, 05:57 PM
cbxterra cbxterra is offline
Member: #18847
if you're not sure do what I did. I cut the end links to the body [bolts wouldn't loosen] then took off the brackets on the axle. It sat on the garage floor for a couple of months just in case. went to the dump 2 days ago in a clean up. I haven't noticed it gone at all. Yeah the truck leans heavily on on ramps, but it did anyway. just have to remember it never will handle turns like my civic does. [but it's way better in snow/ mud etc]
