Roof Rack Fog lights and wiring routing?? - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Tech Talk > Modification Questions
Old 11-19-2012, 09:45 AM
scott-bc's Avatar
scott-bc scott-bc is offline
Seasoned
Member: #22558
scott-bc is on a distinguished road
I was going to add a roof rack light bar on top near the front, that's easy but I was wondering where the best and most practicle place would be to route the wires through the roof. How does a person get the wires that are outside through the roof into the interior of the truck? Would have to be a method so that the roof never leaks? Possibly somewhere near the inside of the stock roof rack mounts to the roof?
Old 11-19-2012, 12:08 PM
yazzagaffix's Avatar
yazzagaffix yazzagaffix is offline
Seasoned
Member: #8615
2003 Xterra
yazzagaffix is on a distinguished road
I ran two relays directly off the battery. From there I fed three 12 gauge wires up to the roof through the passenger side pillar. At the top of the pillar I drilled a hole through the roof under the roof-rack's front-right foot. Painted and grommeted the hole, then after running the wires through it, glopped on lots of electrical grease.
The wires run to an electrical socket that I installed in the roof rack (see build thread page 3). I had run a single 12 gauge ground wire from the passenger side "Oh S**T" handle. Several people thought that would not be enough as I have about 310watts of lights (about 26 amps) so I added another ground wire from one of the roof-rack mounting screws which I scrapped the paint off, then tested the connection) to the roof-rack cross bar.
That was in 2009, and no leaks to date.
2003 XE – 5 speed, 4X4
Removed: resonators, rear sway bar, mud flaps, step rails, factory skids
Added: full skids, shrock sliders, K&N Air Filter, 6" shackles, upgraded rear springs, IAB, heavy duty TRAs, 31-10.5-15 MTZ Mud Claws, Bilstein shocks
Mods: 2" PML, Xterra roof rack cross-bar lights
My modest build thread...
http://www.clubxterra.org/forums/showthread.php?t=23684
