Timing belt change gone bad - Nissan Xterra Forum
post #1 of 20 Old 11-16-2012, 06:45 PM Thread Starter
fuzzytek
fuzzytek is on a distinguished road
Well, a couple of months ago I did a full timing belt, water pump, seals,and thermostat change. I was kind worried of over tension on the belt but the scale said 22# and it didn't whine when i started it up. Fast foward to Wednesday at 60mph on the expressway and lost everything. Tow it back to the house and take the top cover off, not a lot of tension. Slowly turn crank a little a ratchet and belt doens't move. FUDGE. I haven't taken the lower cover off yet, but has anyone ever lost a tensioner? Truck drove 5k miles since it's been back together, and I can't think of what else it could be.
fuzzytek is offline
post #2 of 20 Old 11-16-2012, 07:17 PM
RacerXXL
Quoted: 72 Post(s)
2000 XE Xterra
Garage
Did you replace the tensioner when you did the belt?
RacerXXL is offline
2000 XE Xterra
post #3 of 20 Old 11-16-2012, 07:29 PM
Xterra Mike
Silver Submarine
Xterra Mike's Avatar
Quoted: 13 Post(s)
2001 SE Xterra
Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough
Garage
I wonder if you broke the key off the crank or if you stripped teeth off the belt. I stripped 4 teeth off my belt. Let us know what you find.
Xterra Mike is offline
2001 SE Xterra
post #4 of 20 Old 11-16-2012, 07:32 PM Thread Starter
fuzzytek
Yes. I bought the full kit from Courtesy Parts. I used the factory service manual for all torque settings.
fuzzytek is offline
post #5 of 20 Old 11-16-2012, 07:33 PM Thread Starter
fuzzytek
I will take the lower cover off tomorrow A.M. I'll put pic's up if it turms out to be interesting.
fuzzytek is offline
post #6 of 20 Old 11-16-2012, 07:37 PM
Xterra Mike
Silver Submarine
Quoted: 13 Post(s)
2001 SE Xterra
Garage
Im very curious. I've done about 6 or 7 timing belts and the only problem I've had was a belt was too tight.
2001 SE Xterra
post #7 of 20 Old 11-18-2012, 02:45 PM Thread Starter
fuzzytek
Here are a couple of pics:
Name:	nissan timing 002.jpg
Name:	nissan timing 003.jpg
fuzzytek is offline
post #8 of 20 Old 11-18-2012, 02:48 PM Thread Starter
fuzzytek
First pic shows some of the rubber dusk that is all over behind the covers. The second is self explanitary.
fuzzytek is offline
post #9 of 20 Old 12-04-2012, 06:07 PM Thread Starter
fuzzytek
Well a little more digging and found left side cam shaft siezed tight. That explains the crank killing the belt. Now what to do with the truck?
fuzzytek is offline
post #10 of 20 Old 12-05-2012, 06:24 PM
Xterra Mike
Silver Submarine
Quoted: 13 Post(s)
2001 SE Xterra
Garage
hmmm
2001 SE Xterra
Gear in this thread - Powered by O'Reilly Auto Parts
