Lost 1st gear - Nissan Xterra Forum
post #1 of 9 Old 11-16-2012, 06:51 PM Thread Starter
mzmtg
mzmtg is on a distinguished road
Lost 1st gear
1st gear just quit working in my X. I went to accelerate from a stop sign and there was a bit of a lurch and now first gear will not engage.
Luckily, I can pull away in 2nd most of the time & 3rd through 5th are working fine too.
Any tips on what the root cause might be?
Sent from my StarTac
2001 XE V6 4x4 5 4-speed manual
Just Blue
Build Thread
mzmtg is offline
post #2 of 9 Old 11-16-2012, 07:25 PM
muadeeb
Banned
Pull the drain plug and see if there's metal on it.
muadeeb is offline
post #3 of 9 Old 11-16-2012, 08:09 PM
intender
intender's Avatar
Quoted: 1 Post(s)
2000 SE Xterra
Garage
is it like something is keeping you from physically putting it into gear, or can you get it into gear and then nothing happens. and grinding or other nasty noises associated with it?
My first guess in any situation of a single gear not working, particularly if you cant get it into the gear is synchronizers. I have never tried to change them, and other than knowing what they are couldnt tell you much else.
first things to check would be your clutch fluid reservoir and make sure it isnt low, and then make sure some kind of debris hasnt gotten around the shifter linkage and blocking it. I had a rock end up binding my shifter linkage in a old car and could not get it in reverse no matter what I did.
<<<-click for build
intender is offline
2000 SE Xterra
post #4 of 9 Old 11-17-2012, 08:19 AM Thread Starter
mzmtg
When I try to engage first normally, there's no noise and no movement of the truck.
If I lean hard on the shifter, it will grind like it's partially engaging,, but I can't push the lever hard enough to get it all the way engaged.
Just Blue
Build Thread
mzmtg is offline
post #5 of 9 Old 11-17-2012, 09:56 AM Thread Starter
mzmtg
The first time I drained it (about 4 years and 50k miles ago) there were some disturbingly large chunks of metal on the drain plug. But the truck ran fine up until then and up until yesterday.
Just Blue
Build Thread
mzmtg is offline
post #6 of 9 Old 11-17-2012, 11:02 AM
muadeeb
Banned
http://www.xterranation.org/showthre...ission-rebuild
At least you'll know what you're in for...
muadeeb is offline
post #7 of 9 Old 11-17-2012, 02:27 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
For anyone thinking about tackling a manual gearbox rebuild take a long look at that thread. Very complex and requires access to specialty tools the average guy does not have.
RacerXXL is offline
2000 XE Xterra
post #8 of 9 Old 11-18-2012, 08:20 AM Thread Starter
mzmtg
I could probably do that, but I don't have the time or the garage space.
Looks like finding a used or rebuilt trans is my plan.
Just Blue
Build Thread
mzmtg is offline
post #9 of 9 Old 11-30-2012, 02:37 PM Thread Starter
mzmtg
On the upside, having no 1st gear to use has improved my fuel economy by 5%.
It went from an average of 18.2 mpg to 19.2 on the last tank.
Just Blue
Build Thread
mzmtg is offline
