New shocks, knocking noise on front right on bumps - Nissan Xterra Forum: Xterra Forums
Old 11-16-2012, 02:21 PM
bernasty bernasty is offline
Member: #27420
bernasty is on a distinguished road
So I put new shocks on a couple weeks ago, and I noticed that occaisionally there is a knocking sound when I go over speed bumps on the front right wheel.
So I jacked the front end up and shook the wheel to see if I heard anything. I didn't. I looked around...everything seemed to be OK, tie rods, etc. I put it back down and drove it and the very first speed bump I went over, it made the same noise. It sounds like something is loose, gets jarred a little bit and then makes one single knocking noise.
So at this point, I'm not really sure what it is. So I drive over like 5 more speed bumps, and there's no noise.
I'm honestly not sure if the noise was there before replacing my shocks or not, and I just didn't notice it until now because I'm hyper-sensitive to it, or if it's something wrong with the new shocks.
Does anyone have any idea what this might be? Is it my ball joint or something? How do I check?
2001 Xterra SE 3.3L
Getting 19MPG right now. I'm proud of that, but want to get more out of it. I'm considering an HHO setup.
Old 11-16-2012, 03:29 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
First, what kind of shocks are they? If they're preloading the springs more than stock then they'd definitely make some noise going over speedbumps and make the ride harsher.
The Project Goes On...
Old 11-16-2012, 03:45 PM
Member: #27420
The shocks are Monroe Reflex (911171/2). I got them from Rock Auto. The front left, doesn't seem to be making the same knocking noise. The ride seems fine...doesn't seem any harsher than normal. I know...should have gotten bilsteins, but I'm too poor for that right now.
The only other thing I can think of is that I went to BrakeMax to get my rotors turned and maybe they didn't tighten something back down?
2001 Xterra SE 3.3L
Old 11-16-2012, 04:32 PM
Revu's Avatar
Member: #27745
2005 Xterra
I've gotten bump sounds from the shock cap when turning the wheel because the seat wasn't clocked properly, but a bump only on the passenger side and only when going over a speed bump... my guess would be it might still have something to do with the spring seat. If the spring wasn't set properly inside the groove of the seat then it's possible that the spring is actually shifting in the seat during decompression and making that bump sound.
Old 11-17-2012, 07:10 AM
iwashmycar's Avatar
iwashmycar iwashmycar is offline
Member: #31171
2003 Xterra
iwashmycar is on a distinguished road
An 01 doesnt have springs. Has bars
You can turn the wheel, reach back, and check the tightness of the strut top bolt. Heck you can replace the front shocks with it still on the ground lol
-Adam
2003 Nissan Xterra XE 2WD AT
2007 (O|TOYOTA|O) FJ Cruiser 4WD AT
Old 11-17-2012, 10:03 AM
ShiftingSkys's Avatar
Member: #16608
1.0-1.5 gens have torsion bar set ups. See if you can get a friend to look at the X while going over a bump.
If you cannot do that you could try to simulate the speed bump with two jacks and look up under and see if anything is causing it.
2002 Nissan Xterra
Lifted and Ready to Roll!
Old 11-17-2012, 10:38 AM
Revu's Avatar
Member: #27745
2005 Xterra
Bah how'd I forget that
Then the next thing would be to check the steering linkages during compression.
  #8
Old 02-05-2013, 07:47 PM
roamingxterra's Avatar
roamingxterra roamingxterra is offline
Member: #13030
roamingxterra is on a distinguished road
Bernasty, did you ever find the solution to this? I have a similar issue with the front drivers side. When I go over a speed bump or a large dip at a slow speed, I get a knock at the end of the bump. I go over the bump, but it's like the truck gets back to normal ride and that is when I hear the knock. Sometimes I think I can feel it on the floor by the brake pedal. It doesn't do it when I hit pot holes or other things in the road. Someone at work told me it might be the bushings on the strut. Any other ideas?
2004 Nissan Xterra XE "Everything You Need, Nothing You Don't"*
*Excluding mudflaps, sidebars, swaybar, and bigger tires (Goodyear duratacs to be exact)
  #9
Old 03-07-2013, 07:55 PM
Member: #27420
Hey sorry...forgot to check this thread.
Ok so some of my knocking noise was coming from a loose nut on the sway bar in the back. it would be fine most of the time and then all of the sudden i'd get a knock. It was the sway bar flexing/moving and the bolt sliding and hitting the opposite end of the hole it went through. I just tightened that up and that stopped 90% of the noise.
The rest of it is my ball joint going bad I think. About time to replace it. There's a how to thread on here for that. I am going to do mine pretty soon.
2001 Xterra SE 3.3L
