Changing diff oil. Which rear one do I have. - Nissan Xterra Forum: Xterra Forums
Old 11-15-2012, 01:51 PM
Scottybones Scottybones is offline
Member: #15154
Scottybones is on a distinguished road
Looking through the FSM and noticed that there are 2 different rear diffs listed, one having a far bigger oil capacity than the other. How do I tell which one I have? It's an 02 XE V-6.
Old 11-15-2012, 03:20 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
The easiest way to tell is by what engine you have. If you have the 2.4L 4 cylinder engine then go by capacities for the KA24DE, if you have a 3.3L V6 then go with what it says under VG33E-R.
That should get you all taken care of
The Project Goes On...
Old 11-16-2012, 06:02 AM
Member: #15154
Cool, one more question. Is there a way to tell if its an lsd without jacking the rear end up?
Old 11-16-2012, 07:31 AM
Xterror04's Avatar
Xterror04 Xterror04 is offline
Member: #8609
Xterror04 is a jewel in the roughXterror04 is a jewel in the roughXterror04 is a jewel in the roughXterror04 is a jewel in the rough
Sometimes there's a sticker on the rear diff, the easiest thing to do is just buy fluid oil that already has the additive
Build Thread
Old 11-16-2012, 09:27 AM
Revu's Avatar
Member: #27745
2005 Xterra
Yup there'd be a little white sticker in the center of the cover. It's not an easy one to take off either so it would still be there.
