2000 X misfire issues! - Nissan Xterra Forum: Xterra Forums
Old 11-13-2012, 02:15 PM
Clutch Kick Clutch Kick is offline
Member: #37391
Clutch Kick is on a distinguished road
Hello fellow xterra owners, I suppose it is time to stop surfing unregistered and ask some questions of my own!
I've got a 2000 xterra, with 156k on the clock. Purchased the truck a month ago with a snapped timing belt, and got it to run by replacing the belt! Unfortunately, the truck had been sitting for a few months, with unknown maintenance before my ownership. Since the timing service, o have replaced
-distributor assembly, including cap and rotor
-plugs (denso) and wires
-fuel filter
-air filter
-cleaned MAF sensor
-seafoamed vacuum system and fuel system
After all of this, my X STILL has a p0300 random misfire, and p0325 knoll sensor code. So I am out of ideas, and not sure where to turn next...
Old 11-13-2012, 02:24 PM
Member: #37391
I should also note that the distributor fixed te majority of my idle issues, but drivability is terrible. The engine will not free rev passed 3500 rpm without load, nor will it exceed 3500 rpm while under load. It's like it hits a wall in Any gear.
Old 11-13-2012, 04:15 PM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
This makes me think of a bad MAF Sensor or bad connection in the plug.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 11-13-2012, 04:45 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
I like that handle, Clutch Kick. Another reason why I miss my manual trannies
MAFs can be finicky, sometimes they take well to cleaning, sometimes they don't.
After it was sitting for all the time was the fuel drained before it was started again? I've had plenty of issues with fuel injectors clogging with bad fuel. Most of the time I don't get them working even after cleaning, they need to be replaced completely. They're tricky to test though as you've got to pull them and take them someplace that can put them under pressure.
Hopefully that'll give you a place to start and lead you to the problem really soon.
The Project Goes On...
Old 11-13-2012, 08:06 PM
intender's Avatar
intender intender is offline
Member: #30982
also if you didnt drain the tank, the fuel filter is possibly clogged again. Also if you had the throttle position sensor off for any reason, it may need to be adjusted.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 11-13-2012, 09:11 PM
Silver Submarine
Member: #2784
2001 SE Xterra
Bad fuel was my next thought.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
Fan Club:
Old 11-14-2012, 04:42 AM
Member: #37391
You guys are right on top of helping out, very cool. Clutch kick comes from my 240sx, it's more fun sideways
How do I go about adjusting the throttle position sensor? The fuel tank was drained completely, and filter was changed after two tanks of gas. Is there any place on the fuel rail that a fuel pressure tester can be used, didn't notice one.
Also, is there a chance that my cats could be clogged?
  #8
Old 11-14-2012, 08:53 AM
Revu's Avatar
Member: #27745
2005 Xterra
I love how many of us have come from a 240SX background That's where I got most of my experience modding cars from too. Buggery S13, broken more often then it's drifting... yet why do I love it so much?!
As far as the TPS goes, you may have some luck reading through this thread.
For the fuel injectors, I'm not sure about the 1st gen fuel rail, you may be better off having them checked one at a time.
The cats should have their own code if they clog or have something wrong with them that the sensor picks up. I think it's P0420(?) that the cats throw. I should know that was the first thing that ever happened with my X lol.
Good luck running that code down, I'm sure it won't put up a fight for much longer!
  #9
Old 11-14-2012, 02:41 PM
Member: #37391
Adjusted my TPS, not the issue. Runs much worse disconnected. Disconnected my MaF, andunfortunately seemed to run smoother without it... Might be in the maker for a replacement piece. Cleaned te objections for my TPS, MAF an distributor. Idle misfire appears to be gone for the moment. My PCV system seems a little gummed up still, going to try and seafoam it again tonight. My poor xterra has been abused in the past, but she has found a good home now! I'd love to stop buying maintenance parts, so I can start buying suspension parts
  #10
Old 11-23-2012, 10:22 AM
Member: #37391
Update! Replaced mass air flow an PCV to no significant improvement. Thinking I'm going to have to pull injectors now..
