02 Xterra fuel injector - Nissan Xterra Forum: Xterra Forums
Old 11-13-2012, 11:21 AM
raptor99 raptor99 is offline
Member: #28208
raptor99 is on a distinguished road
Does anybody know if the S/C Xterra have the same fuel injectors as the non- supercharged Xterra? There are several colors of injectors at the part stores and I'm wondering if there is a difference. Also does any body have or know where I can get the individual wiring harness for a single fuel injector? I checked with the Nissan dealer and Nissan only sells the complete wiring harness at a hefty price. Any help is appreciated, thanks
Old 11-14-2012, 12:18 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
The Supercharger probably needs more fuel than the non-sc so it would need a different fuel injector.
In looking at this page on Parts Geek it looks like they have it listed which ones are for non-sc or Naturally Aspirated and which are for Supercharged engines.
As far as wiring them in individually you'd probably have to do some custom harness work. I was a little confused though, are you needing harness that's been modified that runs cabling for just one fuel injector or are you needing just the socket end on the harness side for the injector? If it's the socket end, I'd cut one out of a wrecked X at a junk yard and then solder it in place on the existing harness.
Good luck!
The Project Goes On...
