2001 3.3 Replaced Thermostat - Nissan Xterra Forum: Xterra Forums
Old 11-12-2012, 11:00 AM
Soccerfan Soccerfan is offline
Member: #36693
Soccerfan is on a distinguished road
Newly purchased 2001 X 3.3 4WD purchased for offspring to drive, 128K on the clock.
Have posted before about the issues I'm chasing to be sure vehicle is dependable before turning it over.
Throwing code 1126, and prior owner said her mechanic said this was nothing to worry about. My reading of the forums indicate this is (was) likely a bad thermostat that did not allow the vehicle to warm up properly before opening, and I'm anal, so I just had to change the thermostat. NAPA had the part, and a piece of the lower hose between the thermostat housing and a metal hose, so I acquired, along with a gallon of official Nissan coolant, and spent my Saturday morning (ok, it was most of the day) getting after this.
The radiator drain was right where it was supposed to be, hidden behind a
rubber shield held on my clips in the front and rear. came off easily enough,
and the drain screw actually came out, so I drained about 3 quarts of fluid out and then started disassembling.
Removed battery for more room, the upper hose and pondered taking the shroud off, until I determined that I'd have to remove the fan clutch too, so I just took it loose so I could move it about. Of the three bolts holding the housing on, two are accessible with the proper length extensions, and the third only with a universal joint. Taking if off was the least of the battle.
I was hoping to get this done without taking the belts bracket loose. Putting it all back together was an exercise in frustration, because my big hands couldn't reach the third bolt to get it started, and using the extension to try to thread it in there resulted in a cross threading, so then I had to scratch my head and think outside the box in how to correct. I thought about running a smaller bolt entirely through the housing, attaching a lock washer and nut on the backside of the housing and tighten it down, but I couldn't get my fat paws back there to hold the nut in place to get the bolt threaded on. After much whining and knuckle scraping I went back to the hardware store, purchased a stainless steel metric bolt the same size and hand threaded it into the back hole by standing on my head,holding my breath and praying at the same time. I used a box end wrench to slowly use the harder metal to correct the threads I had boogered earlier, half a turn in, quarter turn out, half turn in, and so on. After I had it going a little, switched from a box end to a 1/4" drive ratchet with a shallow socket and that went much faster.
I did end up taking the belt bracket loose to give me more room.
Topped off the radiator and overflow tank with fresh coolant ( couldn't find the air release bolt on top of the intake, but thread-review this morning showed me where it is....tonights project).
Drove around a while. On my way in to work this morning my scanguage indicates the vehicle runs at 186-188 on the highway, with ambient temps in the 40's. Since this is a new-to-me vehicle, I have no history. With a 180 thermostat in there, is that what others see as their operating temp?
I'm sort of suspecting I have an air bubble, but I'll find out tonight.
Old 11-12-2012, 02:44 PM
muadeeb muadeeb is offline
Banned
Member: #29357
I would see 190-200 during the summer. You may have a bubble, but you're running about right. Next up: Super Charged radiator; thicker and you'll run about 10* cooler.
Old 11-12-2012, 03:18 PM
miskywhisky miskywhisky is online now
Member: #9010
miskywhisky will become famous soon enoughmiskywhisky will become famous soon enough
lower 40's i see 182 on mine doing 60-65mph.
Old 11-13-2012, 09:34 AM
Member: #36693
So this morning I took off the radiator cap, took out the air release bolt, started her up cold and stood around to see what would happen.
At about 150 degrees the X burped out both the radiator and the air release hole a large air bubbule, and then a couple of ounces of coolant, so I scurried around and buttoned them both up. Ran by the car wash and washed the coolant off everything and drove in to work. Today the scanguage stayed right on 184 all the way in. I think I can live with that, with a 180 thermostat.
Now, my next question has to do with the auxilary fan on front of the radiator for the A/C. On a prior vehicle I took out the fan clutch, attached a e-fan to the shroud using cable ties, and wired it to come on when the A/C condensor fan came on. This worked like a champ. On the Xterra, I can't seem to make the A/C fan come on. Turning on the air doesn't work, and the temps here now are not high enough, and won't be again for a while, to induce that aux fan on. Any ideas?
Old 11-13-2012, 01:06 PM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
That fan should automatically turn on when you turn the AC on. It might be broken. Jump it straight to the battery and see if it turns on.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
