New York Noob - Nissan Xterra Forum: Xterra Forums
Old 11-11-2012, 10:19 PM
Ratt Ratt is offline
Member: #37200
Ratt is on a distinguished road
New York Noob
Hello all,
My names Andrew and my wife and I just moved to "Upstate" New York. I just bought a 02 Xterra after failing to find a Wrangler. Just Happens to pop up on craigslist while perusaling for an affordable winter vehical. This is a huge step outside my comfort zone. Ive been an Air Cooled VW guy for ages but had to leave my Bus back home in Washington while I'm out here for work.
So far my impression of the Xterra are good. However I already find myself with a few issues. I have a bad O2 sensor, a "gross leak" in the evap system , and something about a coolant sensor. Seems the PO cleared the check engine light with a new battery and failed to mention it. Luckily I got a good deal or I would be slightly upset.
Anyways I look forward to joining the community and learning what I need to deal with these computer controlled cars.
Andrew
Old 11-11-2012, 11:03 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
Welcome to the club!
Yeah it stinks when previous owners rigged stuff to work and "forget" to say anything about it when they're offloading it onto someone else. That's a definite sign to check for other maintenance issues that might have been skipped over or rigged up.
Overall the Xterras are great vehicles and will put up with a lot of abuse. Though if it has it'll probably just take a little bit of time to get it caught up on everything it needs so it will be sure to stay reliable for a long time to come.
The sensors are a pain when they go but fortunately aren't too bad to wire in. The evap leak is going to be worse to pin down, hopefully it's not making pumping fuel a big issue yet.
Definitely have the timing belt checked. That's the big expensive fix that V6 Xterras need as they pass the 100k mark.
I'm sure once it's caught up it'll be a great vehicle for you. Take care, and have fun!
The Project Goes On...
Old 11-12-2012, 04:29 AM
2011Pro-4x 2011Pro-4x is offline
Member: #31902
2011 Xterra
2011Pro-4x is on a distinguished road
Welcome, from another New York member.
Old 11-12-2012, 05:27 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Welcome to the site.
Old 11-12-2012, 06:29 PM
yellowx16's Avatar
yellowx16 yellowx16 is offline
Member: #21093
yellowx16 is on a distinguished road
welcome, what part of upstate? I am in rochester.
Calmini PML, ARB Winch Bumper, 31x10.50r16 BFG all-terrains, 2 inch DIY BL, 16x8 Vision Wheel Warrior, custom cold air intake, Pro Comp ES3000 Hydro shocks,Pro Comp steering stabilizer, sway bar removed, Pro Comp 6 inch HID lights, rigid dually leds
Build Thread-http://www.clubxterra.org/forums/sho...d.php?p=510153
Old 11-12-2012, 07:33 PM
Member: #37200
Thanks all! I am just north of Albany in Ballston Spa. They consider this place "upstate".
