@ your next oil change, get an oil pan gasket and change it out with the oil that should help that, i read an interesting article that said a sign of bad pcv valve could be leakage of oil from seals and a loss of power and or rough idle and i went to pull mine to check it. it was rattling like it should but had crusted up oil all on it and in it (it was factory! 13 years!) so i replaced it ($3.99 at autozone) man what a difference! more power smoother idle and slowed the leak i think its almost stopped! heres a link to the article:
http://www.ehow.com/list_7541495_sig...pcv-valve.html to follow up it has slowed the leak, no longer a drop after every trip that is more than a few miles just a drop occasionally, so it did mess up my rear main seal
