Xterra/Pathfinder rim swap - Nissan Xterra Forum
post #1 of 5 Old 11-09-2012, 11:28 AM Thread Starter
Piper Mike
Piper Mike is on a distinguished road
I have a 2004 Xterra XE L4 2WD with the 15 inch steel wheels
I wanted to know if the 16" Alloys from a 2003 Pathfinder will fit on my Xterra. I do know that the bolt pattern is the same but I was wondering about the hub size or any other issues ?
Piper Mike is offline
post #2 of 5 Old 11-09-2012, 03:12 PM
Revu
Revu's Avatar
2005 Xterra
More then likely you'll be fine with the properly sized tires. What you'll want to make sure of is that the Pathfinder wheels don't have more backspacing than your stock wheels. That's highly unlikely as the stock wheels on the X have quite a bit of backspacing. But your biggest priority is going to be sure you don't rub against the suspension.
So Keep you backspacing about the same and your tire size appropriate for it and you'll be fine.
Revu is offline
2005 Xterra
post #3 of 5 Old 11-09-2012, 08:49 PM
Xterror04
Xterror04's Avatar
Quoted: 2 Post(s)
Xterror04 is a jewel in the rough Xterror04 is a jewel in the rough Xterror04 is a jewel in the rough Xterror04 is a jewel in the rough
You wil be fine you don't have the 4x4 Hubs so it will bolt right up
Xterror04 is offline
post #4 of 5 Old 11-09-2012, 10:45 PM
saks
Seasoned
saks's Avatar
saks will become famous soon enough
I went from 2001 stock 16"s to pathy 15"s no problem. Even with 4WD
saks is offline
post #5 of 5 Old 11-12-2012, 05:34 AM
cbxterra
Quoted: 31 Post(s)
Garage
another possibility- I'm using the 15" rims off my old 00 Frontier as winter rims on my 00. So maybe a pair off one of them.
cbxterra is offline
