a myriad of problems - Nissan Xterra Forum: Xterra Forums
Old 11-08-2012, 11:04 AM
abaker1381 abaker1381 is offline
Member: #37239
2006 Xterra
abaker1381 is on a distinguished road
hello all, this is the first post so i apologize if i make any error or break posting rules.
I have a 2006 X manual OR, just bought it back in Feb.
about 2 weeks ago i started to get the heatshield vibration on the driver side
- ok easy fix =D
shortly after i had an issue were i could only start the X by pressing the clutch start button.
-np came down to the little button that the clutch compresses when you start.
about a week ago my driverside window started giving me issues.
-bad motor (imo)
2 days ago i got an issue where i have no power from the X.... not electrical power but get up and go power. in first gear i had to rev to about 2500-3000 rpms just to get moving... all of the gears are like that. it seems to work a little better once warmed up. the rpms also jump a it when i try to accelerate then even back off.
-this... i have no idea what the prob is lol
thank you guys in advance for ur time and any info on this latest problem would be greatly appreciated.
Old 11-08-2012, 12:02 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
My guess would be it's time for a new clutch. How many miles on the truck?
Old 11-08-2012, 12:12 PM
Member: #37239
2006 Xterra
sorry, should have posted that. 77000
Old 11-09-2012, 08:45 AM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
When you say you have no get up and go power, does the engine at all sound funny? When you have it sitting in neutral does it vibrate or variate in RPM or give any sign that you might be having engine trouble?
If the engine seems perfectly fine then the clutch is definitely a good place to start. It would make sense if the clutch isn't making full contact pressure when you release the clutch pedal that only a small portion of the engine power would be going to try turning the wheel, therefore you're needing to generate a lot more power to get it to move.
It also could be one of the clutch cylinders doing that...
The Project Goes On...
Old 11-09-2012, 10:50 AM
Member: #37239
2006 Xterra
engine sounds fine and no variation of rpms in neutral. the clutch not making full contact is exactly what it feels like power wise. ill get it checked out. thanks for the replies
Old 11-09-2012, 11:37 PM
xtacular's Avatar
xtacular xtacular is offline
Member: #13879
How many of those miles have you driven? Are you a proficient stick driver? 77k is pretty low for the clutch to go, but one can be ruined in 1 day with bad enough driving. Maybe slave cylinder?
2002 Super Black 5 Speed 4x4
Shovel Mount
Old 11-10-2012, 12:21 AM
Member: #37239
2006 Xterra
I've only had it for 5k but im 30 and every vehicle I've owned has been manual. Never had a clutch or transmission problem before.
  #8
Old 11-10-2012, 12:08 PM
Revu's Avatar
Member: #27745
2005 Xterra
Slave cylinder makes a lot of sense. I had an old Nissan that when that had problems the gears would grind even though the clutch was fully depressed. Kind of the opposite problem of what you're having, but could be similar components.
That's one of the issues with used is you really have no idea how the previous owner treated it. That old Nissan car I drove I had purchased from a high school kid who treated the clutch pretty bad, and I eventually just changed out the clutch, lines, and cylinders to negate the issues.
Hope you're able to get that sorted soon and as painlessly as possible!
Tags
heatshield, power loss, rpm, transmission
