Tires - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Offroad Modifications 2nd gen (05+) > Offroad Wheels & tires
Old 11-06-2012, 07:12 PM
USA450R USA450R is offline
Member: #19469
2009 Xterra
USA450R is on a distinguished road
Tires
Can I fit a 275/70/18 tire and wheel on a 09 Xterra S without rubbing and such?
USA
Old 11-06-2012, 08:33 PM
TJTJ's Avatar
TJTJ TJTJ is offline
Member: #374
TJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to behold
Talking
USA
Probably not...unless you melt back the plastic at the front wheel well out of the way to make the teeny amount of clearance you'll need to clear them. "Melt Mod"
32's fit stock, and those 275/70/18's are roughly 33", so they protrude a bit more than 1/2" more (~ 0.65" or so depending on which tire exactly)
Some people can fit 33's w/o any melt mod, but there's a bump in the plastic wheel well liner that touches the tires on most 2005+ X's.
There's nothing behind the bump...so people just use a blow drier or heat gun to melt it down so its not sticking out any more.
-TJ
Old 11-06-2012, 08:50 PM
Member: #19469
2009 Xterra
Thumbs up
Gotcha, thx!
Gents - What is the easiest and cheapest way to get a couple inches of lift? I will not do this myself so I will need to pay a shop too.
Recommendations? What do you think this will cost?
Thanks in advance,
USA
Old 11-07-2012, 03:29 PM
piratex's Avatar
piratex piratex is offline
Member: #22549
2006 X mt Xterra
piratex is on a distinguished road
i think based on all your new thread maybe you should do some searching on this forum and thenewx.org
as for lift there are both bodylift and suspension lift options. how big depends on your pocket book.
nissanonlineparts.com sells a 2in body lift for about 200 bucks. and then suspension lifts can range from 250 bucks to endless. what u want to spend depends on the amount of lift and quality of lift.
like i said earlier checking out the lift options on both sites will help and also not create so many threads
pirate in all aspects of the term.... well somewhat.
"i understand its a jeep thing, thats why i drive a XTERRA"
Old 11-07-2012, 03:31 PM
piratex's Avatar
Member: #22549
2006 X mt Xterra
you can only fit 285 75 16 or the equal. which is about a 33x11.5x16. the only way to get any bigger is based on widening the stance with longer upper and lower control arms(front) and wheel spacers in the rear.
Old 11-07-2012, 04:10 PM
Member: #19469
2009 Xterra
I guess I was lucky. I put 275/70/18 on today. No rubbing or anything at full turn I just need a little 2" BL now to make her look a little better.
USA
2009 Xterra
275/70/18 Toyo MT
Old 11-07-2012, 04:41 PM
Member: #19469
2009 Xterra
Shoes
New shoes......275/70/18
Your file of 5.98 MB bytes exceeds the forum's limit of 2.00 MB for this filetype.
Guess not...
2009 Xterra
275/70/18 Toyo MT
  #8
Old 11-07-2012, 04:50 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
Yeah sorry, 10 mega pixel photos don't upload well as attachments. You'll want to compress the photo down to a more manageable size using some photo editing software or upload it to imageshack. It'd definitely be cool to see how your tires came looking!
The Project Goes On...
  #9
Old 11-07-2012, 05:54 PM
Member: #19469
2009 Xterra
I'll try to scale it down.......
2009 Xterra
275/70/18 Toyo MT
  #10
Old 11-07-2012, 08:30 PM
Member: #19469
2009 Xterra
Lets try again
New shoes and wheels
2009 Xterra
275/70/18 Toyo MT
