Bad Gasoline!! Drain Tank? - Nissan Xterra Forum: Xterra Forums
Old 11-06-2012, 05:20 AM
RockMozart13's Avatar
RockMozart13 RockMozart13 is offline
Member: #5030
'02 SE S/C Xterra
RockMozart13 is on a distinguished road
Ok thanks to Sandy and the resulting gas shortage, I got some bad gas.
It was in a 5 gallons container, I poured some out to look at it, it was the color of beer, but not cloudy. Regardless it turned over fine, slightly higher idle 1k rpms, but not long after started to "grumble" in low gears, on the highway it was fine, but stalled out right before my house waiting at a red light.
Do I drain the tank? Can I siphoned the gas out? Do I have to flush the tank? How?
Taking the train to work for now, not going anywhere until this is fixed.
Help please.
2002 SE S/C Sedona
XOC/LINXC Member Since '04
Goodyear Wrangler ATS 275/70/17, PML, Intake Resonators Removed, Drop In K&N, Flowmaster Cat-Back, Rancho RS5000s, LOBO Rack, Interior LED Map/Dome Lights
To Do: Repaint Plastics(Again), Custom Sliders, Knock Sensor Relocation, SoundRacer V8 Mod
Wishlish: 32" ATs, PML, 2" BL, Sliders, UCAs,
Facebook Photo Bucket
Old 11-06-2012, 05:54 AM
TJTJ's Avatar
TJTJ TJTJ is offline
Member: #374
TJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to behold
Talking
Drain and flush the tank, and the fuel lines/engine, etc. Then clean the injectors, etc.
-TJ
Old 11-06-2012, 07:56 AM
Member: #5030
'02 SE S/C Xterra
Thanks TJ
Yeah drain the tank was my first thought, but can we siphon gas out, or do I have to drop the tank? Not in a great position to work under the car, (city streets, no jack stands, no readily accessible tools).
A productive question is does anybody have experience draining the tank, either by siphoning or disconnecting the lines, etc?
2002 SE S/C Sedona
Old 11-06-2012, 08:09 AM
intender's Avatar
intender intender is online now
Member: #30982
dont forget to replace the fuel filter. I got some bad gas after a flood that was full of water and the truck took a while to run right. I tried siphoning the gas out but couldnt get it all out. Had to drop the tank anyway (mouth full of gas for nothing) went through about 3 filters and several plugs before it finally seemed like it cleared up and ran right. but that was an 81 chevy scottsdale and it was a finicky miserable beast to drive anyway. The carb was all screwed up, stupid spaghetti hoses on the stock carb were a pain.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 11-12-2012, 05:53 AM
Member: #5030
'02 SE S/C Xterra
Ok, took the to the local mechanic, he dropped and drained the tank for $200, new fuel filter and oil change $75. For $275 it was worth it to watch someone else do it.
Now the X is running right and it's got a full tank of gas.
2002 SE S/C Sedona
Tags
bad gas, bad gasoline, gas tank
