New t-bars with pml? - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Offroad Modifications 1st gen (00-04) > Offroad Suspension & Steering
Old 11-05-2012, 03:37 PM
yellowx16's Avatar
yellowx16 yellowx16 is offline
Member: #21093
yellowx16 is on a distinguished road
I did some searching before posting this, but i couldnt really find exactly what i needed. I am going to be doing a pml for sure this winter on my break from school and i'm thinking i will need new t-bars. My reasoning for this is, 1.) i have adjusted my t-bars once before to level the front, and my bumpstop gap is already at .5". 2.) I have an ARB front bumper and i think the added weight sags the front down some already. So, my question is if i buy new sway bars (sway-away, AC or calmini) will i be able to definitely get a leveled pml? I just want to make sure i have a level pml, and im pretty sure the new t-bars will do this right? Also, ive read that the sway-aways ride a little bit stiffer than the calmini and AC bars because of the 30% vs. 20% spring rate, but what kind of experience have you all had with these t-bars? Any input would be appreciated!
Calmini PML, ARB Winch Bumper, 31x10.50r16 BFG all-terrains, 2 inch DIY BL, 16x8 Vision Wheel Warrior, custom cold air intake, Pro Comp ES3000 Hydro shocks,Pro Comp steering stabilizer, sway bar removed, Pro Comp 6 inch HID lights, rigid dually leds
Build Thread-http://www.clubxterra.org/forums/sho...d.php?p=510153
Old 11-05-2012, 05:24 PM
lbishop's Avatar
lbishop lbishop is offline
Member: #18492
lbishop is on a distinguished road
not quite man, the sway aways might get rid of some of the sag from the arb but wont let you get the leveled look because your out of adjustment room. your gonna need a set of uca's )upper control arms. They let you crank the t-bars up further because they bring everything back into the manufactures tolerances
heres a link to the ones on 4x4parts
https://www.4x4parts.com/nissan/xter...lift-p-79.html
and the calmini ones
http://www.purenissan.com/wd22_control_arms.htm
2004 xterra xe 4x4
1/2 PML
265/75/16 Cooper Discover STTs
16x8 Gear Alloy Blackjack Wheels
Bilstein 5100s all around
kenwood xd 794 stereo deck
Rockford Fosgate punch speakers
Bilstein Steering Stabilizer
2 inch body lift
coming soon
iab,hd tras, hd tres, and hd torsion bars
rusto-luem bed-liner on all the plastics and roof rack
Old 11-05-2012, 05:58 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
The AC torsion bars are SAW's.
Old 11-05-2012, 07:08 PM
xtacular's Avatar
xtacular xtacular is offline
Member: #13879
lbishop is on the money, you need upper control arms. The tbars will do nothing to give you more bumpstop gap.
2002 Super Black 5 Speed 4x4
Shovel Mount
Old 11-05-2012, 07:15 PM
yellowx16's Avatar
Member: #21093
alright, so basically new t-bars wont solve anything, i just gotta get new uca's. Makes sense now, thanks for the help.
Old 11-28-2012, 11:44 AM
spasticnapjerk's Avatar
spasticnapjerk spasticnapjerk is offline
Member: #15105
spasticnapjerk is on a distinguished road
Hi everyone. I hope I'm not stepping on this thread, but the Calmini UCAs are part of a 3" suspension lift kit that they sell. It contains a bunch of stuff...leafs, ball joints, UCAs, and new torsion bars that are said to "smooth out the ride."
I have a PML with low-profile bump stops and the ride crashes over every bump. It sounds like the TBs are cranked too much, for sure. I would like to upgrade. Will the Calmini 3" lift kit really make the ride smoother? Thanks for any and all advice, and sorry for asking a question that has probably been answered 1000 times already.
Drew
Honduras
Old 11-28-2012, 01:27 PM
robcarync's Avatar
Member: #33023
Drew
Honduras
It would IF the rough ride is caused by the UCAs hitting the bump stop! The UCAs don't do anything specfically to "smooth" the ride. They are just a big chunk of welded metal. The aftermarket UCAs are narrower to allow a bigger gap between the bump stop. Thus...if you crank your Torsion bars too much so that they hit the bump stops, then replace the UCAs with a narrower arm, you have now have a bump stop gap at the same torsion bar position. If you added low profile bump stops, and still have a gap between them and your stock UCAs, getting new UCAs will not improve the ride quality...they will just give you an even bigger gap between your UCAs and bumps tops!
2004 Xterra 4X4
To Do
Building my X
