Squealing/screeching noise - Nissan Xterra Forum: Xterra Forums
Old 10-26-2012, 02:31 PM
oharag oharag is offline
Member: #37044
2005 Xterra
oharag is on a distinguished road
I searched Google for the following issue that I am having with my 2005 Xterra Off Road -5 sp -(165K):
I replaced the serpentine about 2-3 years ago. I do not know if this caused an issue - though I started to get screeching/squealing noise during acceleration. I have been told it may be the clutch bearing - though this noise occurs when the gear is in neutral - no clutch depressed - and I rev the engine. It occurs during acceleration during driving. Sometimes it goes away during driving. It's usually there all the time.
I thought it was the timing belt - so I had it replaced again. I was told the belt was messed up (aftermarket - bought most likely from Autozone). When the belt was installed I thought it cleared up the issue. Though it started to creep back and become more prominent. I then decided to replace the belt tensioner. Still the noise is there. I'm worried it's a bearing somewhere in the serpentine loop. I read some TSB from Nissan (and I believe it is old) that you need to evaluate the power steering pulley bracket location due to rubbing - or replace the belt/tensioner.
Anyone else have this issue? Any help would be greatly appreciated. I have had the vehicle in for evaluation - though no one has a proposed solution.
Thanks
Jerry
Old 10-26-2012, 02:58 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
Welcome to the club! And oh man that's going to be difficult to pin down.
So you've got a manual tranny, it has a relatively new serpentine belt, timing belt, and tensioner. The noise did go away after replacing the timing belt, but only for a short time. The noise occurs when revving the engine regardless of what gear it's in.
How long ago was the first time you noticed this noise?
When I hear a squeal the serpentine belt is the first place I typically look. I try tightening up the belt to see if that effects it all. If the noise changes then it's related to the belt system, if not look elsewhere.
The serpentine belt will make terrible squeals if it's slipping on the pulleys but it's usually most apparent when the vehicle first starts up, and then quiets down after a moment. A more constant squeal could indicate one of the pulleys is failing. Perhaps the baring on a pulley has given out and is causing the wheel to grind. That happened an older car of ours and we ended up getting metal shavings in the AC system from the compressor that way.
The Project Goes On...
Old 10-26-2012, 03:02 PM
xtacular's Avatar
xtacular xtacular is offline
Member: #13879
Wait wait, what year of X do you actually have? It says 2005 but 5 speeds and timing belts only came on 2000-2004.
2002 Super Black 5 Speed 4x4
Shovel Mount
Old 10-26-2012, 04:30 PM
muadeeb muadeeb is offline
Banned
Member: #29357
Unless he is outside the US. There was another user some time back that had an 05, but is still a 1st gen.
Old 10-29-2012, 02:02 AM
BluesquidNY BluesquidNY is offline
Member: #12478
2005 Xterra
BluesquidNY is on a distinguished road
Does it sound like this?
My clutch fan finally went and was making this noise the second I crossed 3000 rpm's in my manual Xterra.
If any mods read this, Id love to write a sticky on the cluch fan in general. I have learned quite abit about it.
Old 12-05-2012, 03:24 PM
Member: #37044
2005 Xterra
Sorry I meant serpantine belt - not timing belt. I have a 2005 OR - metal timing chain. I understand if it's a timing chanin issue - ther eis a grinding noise not squealing.
The noise is still there. I will investigate the power sterring bracket issue.
I know have an issue with leaking rear seals - aanyone having htese issues - squealing in motor area - or leaky rear seals?
I have seen other posts concerning issues with the rear drive train/axle. Nothing with squealling.
