2008 xterra Automatic Transmission filter? - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Tech Talk > Scheduled or Preventive Maintenance
Old 10-22-2012, 07:41 AM
MikeDiPaolo MikeDiPaolo is offline
Member: #36849
2008 Xterra
MikeDiPaolo is on a distinguished road
I am planning to change the automatic transmission fluid and checked the manual to see where the filter was to replace it as well. There is no mention of a automatic transmission filter in the manual nor did I see on on the drawings. Is that true, the Xterra does not have one ?
Old 10-22-2012, 08:42 AM
muadeeb muadeeb is offline
Banned
Member: #29357
It does, but it's internal to the tranny and Nissan does not recommend regular replacement. Some people add an external filter.
Old 10-22-2012, 08:49 AM
Member: #36849
2008 Xterra
Thanks, I did a search of section TM of the manual and did not even find a reference on an internal filter. By the way, do you recommend casterol Type J fluid or go to Nissan dealership and buy thier ATF Type J fluid
Old 10-22-2012, 11:53 AM
Banned
Member: #29357
J was replaced by S (probably after they realized the SMOD problem). I have a 1st gen (Matic-D) and run Valvoline MaxLife Dex/Merc with no problems, but you will never go wrong with the factory fluid. Can you use Casterol? If it lists compatibility with Matic J/S then yes. Should you? :shrug:
As for the filter, it looks like it's under the control valves, like in the 1st gen tranny, but Nissan now wants you to replace the entire valve/TCM/filter assembly as one unit. If the filter is anything like mine, it's a simple wire mesh to keep the large pieces out of the works; no real 'filtering'.
Old 10-22-2012, 12:10 PM
Member: #36849
2008 Xterra
Thank you for the detailed response, much appreciated.
Old 12-30-2012, 08:42 PM
mexfdmnb's Avatar
mexfdmnb mexfdmnb is offline
Member: #35567
2007 Xterra
mexfdmnb is on a distinguished road
This reply is prob a little late but why not share my info, my x has 87K on it I did the tranny/rad mod and while I was at it i Did the tranny drain and change (aprox 4.5q 2nd gen) I used castrol high mileage just make sure it sais recommended use for nissan matic types. test drove shifts smooth and easy and nice ride
Old 12-31-2012, 01:13 PM
gsxrjason gsxrjason is offline
Member: #38250
2005 Xterra
gsxrjason is on a distinguished road
I just picked up an 05 xterra yesterday, Now doing a little research it would seem I should look into this issue.
Iv looked into this SMOD bypass
Should I have the transmission inspected?
Was the mod difficult to do?
Is there any concerns in doing the mod?
  #8
Old 12-31-2012, 03:04 PM
mexfdmnb's Avatar
Member: #35567
2007 Xterra
If it will make you sleep easier at night you can have it inspected.
When you drain your tranny fluid it should be a dark red color when mine came out it was brownish with a little red tint. It was definitely time for a change.
The mod was not difficult to do you seriously only move 2 lines. you need to remove the skid plate. So all you'll need is a 10mm socket + ratchet and some pliers, there's diy threads on this site.
The only concern Ive read was if you live in a warmer climate and do a lot of towing you might want to add another external cooler, I heard the plate ones are better than tube/fin types you can get one for around 50-60 $ or one with a fan for bout 100-130$
Hope this Helped!
  #9
Old 01-02-2013, 07:47 AM
Member: #36849
2008 Xterra
Thank you for the reply. Do you have a reference for the transmission filter mod. you did, I assume you placed a filter in line to the radiator? What was the filter type/surface area, and any information on the filter housign whould be appreciated...
  #10
Old 01-02-2013, 09:58 AM
Member: #38250
2005 Xterra
Thanks for the reply Mex,
I brought this issue up with a co-worker of mine who has owned an xterra for years and was not aware of this issue. He is looking into adding an additional cooler. I don't do any towing and the pacific northwest here is averagely cool out side of summer.
