ironman4x4 lift kit for xterra - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Offroad Modifications 2nd gen (05+) > Offroad suspension & Steering
Old 10-06-2012, 05:43 AM
tajkeh tajkeh is offline
Member: #30125
2011 Xterra
tajkeh is on a distinguished road
http://www.ironman4x4.com/html/nissan/64.html
Guys ... anyone tried them? how good are they? i am talking about mainly "dune bashing" in the arabian desert (UAE)
Old 10-06-2012, 11:57 AM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
This looks really similar to the Australian Old Man Emu suspension system that I just put on my X. From what I've read, the nitro shocks are intended for bounding over rough and rocky terrain, but I don't see why they wouldn't do great over sand as well.
Typically for fine sand desert running your main concern is going to be weight. You're going to want tires with a wide tread and as light weight wheels as you can find. The more the weight at the end of the suspension displaces the sand after the springs rebound the more likely the rig is to get stuck. Lightening up the body components of your X wouldn't hurt either, like getting rid of useless stock components.
I would imagine the best setup for high speed desert running would be a full spring pack and external reservoir shocks like King or Fox. Wheel travel isn't as big of an issue as much as much as grip and stability is.
I would probably try the Ironman kit out and at least have that as an entry level starting point then make adjustments from there.
Have fun with it!
The Project Goes On...
Old 10-06-2012, 04:28 PM
ATFire22's Avatar
ATFire22 ATFire22 is offline
Member: #20546
00 SE Xterra
ATFire22 is on a distinguished road
actually for desert running. wheel travel is a big thing. unless you plan on driving like a gma on the sand. but if are talking about actual desert running it is. then i would look into camburg kits or like he said fox reservoir kits for long travel. if that's your way of going though be prepared to spend some money. camburg makes a awesome beginner long travel kit.
MyX Build
Old 10-07-2012, 10:35 AM
Revu's Avatar
Member: #27745
2005 Xterra
Yeah, like our style of desert running here in the western US still includes getting over rocks and a whole lot of bumps. My understanding of desert running in Middle Eastern countries like UAE though is that there is very little debris and obstacles to roll over and is mostly just miles of wind swept sand dunes. So the suspension shouldn't be doing nearly the amount of bouncing it does here, just some moderate flexing when going up and down hills.
Old 12-10-2012, 07:48 AM
Siwady's Avatar
Siwady Siwady is offline
Member: #30138
2010 Xterra
Siwady is on a distinguished road
Hello,
Did you end up installing the Ironman kit? Could you give me a quick review. I found a PRG lift kit with AAL on Dubizzle.com and was wondering if anyone knows anything about this kit?
Old 12-30-2012, 10:42 PM
Member: #30125
2011 Xterra
Finally i got the iron man kit, doing great so far, not much of a lift as you mentioned, replaced the stock tires with 285x75 cooper STT, lots of rubbing but a great grip
Thank you all for your comments and feedbacks
Old 01-07-2013, 06:51 PM
ryandavenport's Avatar
ryandavenport ryandavenport is offline
Professional
Member: #15330
2007 Xterra
ryandavenport has a spectacular aura about themryandavenport has a spectacular aura about themryandavenport has a spectacular aura about them
^^Try the melt mod, where you melt the inner wheel well plastic at the back of the wheel well with a heat gun or hair dryer and push it back. That should fix your rubbing issue. I have had that done to mine for some time now.
2007 Xterra S 4x4
Wheels, Tires, and Suspension
285-75 R16 BFG AT-KO, Pro-4X Wheels, 2" OME Lift
NXRocks Skids, TAG Rear Bumper, White-Knuckle Off-Road Rock Sliders
Exterior
Xoskel Bumper Mount Bracket, Blacked out Emblems, Weathertech Vent Visors, FOURTREKS Hi-Lift Mount, Wilson1000 CB Antenna
Pioneer AVHP3200DVD, Midland CB, Compass Mirror, Nissan All-Weather Floor Mats, Nissan Carpeted Cargo Mat
