Gas... Going, going, gone... - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > General > FAQ/Common Questions
Old 09-23-2012, 08:40 PM
ALPINE X's Avatar
ALPINE X ALPINE X is offline
Member: #25622
ALPINE X is on a distinguished road
Recently i have noticed that my 2000 has been burning through gas like no other. I filled it up and tripped the tank and it went 233 which averages about 14-15miles which is expected, but then i filled up again and this time it barely lasted me nearly 180, any ideas of why it could drop so much, i have noticed this has been happening a lot lately and im sick of putting so much damn money into the gas tank every week.
ALPINE X
MDXC (Maryland Xterra Club)
NeXterra (North East Xterra Club)
Xterra Nation (Self Explanatory)
Mods: 4 PIAA up top on self made lightbar, Yakima Loadwarrior, Yakima Big Powderhound, Grille Guard, Deleted steprails/mudflaps, Alpine CDE-122 Head unit, Polk MM6501UM Speakers, Alpine MRP-F300 Amp, JL-12W6v2 Sub, Painted Plastics, J.I.C. and Recovery Gear.
Build Thread
Old 09-23-2012, 09:51 PM
BryceT.York's Avatar
BryceT.York BryceT.York is offline
Seasoned
Member: #34857
BryceT.York is on a distinguished road
had the same thing happen,ive just been driving VERY conservatively(which is hard because i'm typically a very agressive driver) and iv'e been using mystery oil in my gas tank, took off my wind deflector and basket,which stick up a good 5 inches above the roof..other than that,just try to stay off the skinny pedal,thats the problem i have...
"Si vis pacem, para bellum."
2002 SE, 5-spd, 4WD
3" suspension lift
Hella 500's
Straight-piped
JVC KW-HDR720 head-unit
Visonik 750w amp
Two 12" Kicker Comps
Cobra CB radio
5% tint on rear windows
Bed-lined plastics
http://www.clubxterra.org/forums/showthread.php?t=39717
^BUILD THREAD^
Old 09-24-2012, 07:22 AM
ShiftingSkys's Avatar
ShiftingSkys ShiftingSkys is online now
Member: #16608
That is a considerable drop. You want to start at Ignition and then move to air most likely. Either the plugs and wires are very bad or the air thats getting into the cylinder is not what it should be. Possibly badly worn tires/ unalignment?
There are tons of reasons why things could affect gas mileage.
Old 09-27-2012, 11:19 AM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
yeah check your alignment, the 3.3l engines show anything out of order even the slightest, in the fuel economy. also how have you been driving, slow or fast, a lot of city? (more than usual) thats when i notice my mpg go down big time, i get so much better freeway mpg i use freeway if at all possible. go to walmart, and look for a box that says dura lube severe fuel system cleaner and put this in a full tank, then run the little bottle of the dura lube upper cylinder lube the next few tanks (little one looks like lucas bottle) the logo is red techno looking text on a black/yellow backround that stuff works wonders especially in the nissan 3.3l, seems to help most
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
Old 09-27-2012, 03:16 PM
outwiththeold's Avatar
outwiththeold outwiththeold is offline
Member: #4028
00 Xe 4x4 Xterra
Should be like 300 per tank...
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
Old 09-27-2012, 07:01 PM
Pops's Avatar
Pops Pops is online now
Member: #3133
2002/2003 Xterra
Pops has a spectacular aura about themPops has a spectacular aura about them
Gas companies sometimes change formula. Winter gas has more butane and other things that kill mpg. I am commuting over 500 miles per week plus road trips so I picked up a used Mini Cooper S and spend less than $70/week now.
2005 Armada LE 4x4
Old 09-28-2012, 11:26 AM
ALPINE X's Avatar
Member: #25622
God this is getting ridiculous, i just filled up again and will clock it and see how well it goes, if nothing changes i need to find a new way of transport, my mod money is now turning into gas money.
ALPINE X
Build Thread
  #8
Old 02-04-2013, 03:28 PM
FJ Bruiser FJ Bruiser is offline
Member: #38978
07 fj Xterra
FJ Bruiser is on a distinguished road
the cold air we have been having latly could be hurting your milage.
1 cold air will contract, lowering the air pressure in the tires. an easy fix.
2 all vic get lower gas milage in the winter. cold air fuel mix changes etc. no fix.
3. do all the fun easy things oil air and fuel filter change.
I'm thinking you prob have done all this, but just saying.
