balancer/ pulley - Nissan Xterra Forum
post #1 of 7 Old 09-07-2012, 08:50 PM Thread Starter
33xterra
2004 2005 Xterra
33xterra is on a distinguished road
balancer/ pulley
I'm having trouble getting the harmonic balancer off. It is just the two little holes u put bolts in then pull it off with a puller right?
Also the valves could be shot to hell and back when the timing belt broke and I cranked it trying to get it running? Is it hit or miss if anything happened to them? I have heard that they will be fine but I have also heard they will be majorly screwed up.
33xterra is offline
2004 2005 Xterra
post #2 of 7 Old 09-07-2012, 08:59 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
Yep. Remove the crankshaft pulley bolt and washer then thread in the two M6x1 bolts to secure the puller then using an impact pull the pulley.
Pretty much.
RacerXXL is offline
2000 XE Xterra
post #3 of 7 Old 09-07-2012, 09:14 PM Thread Starter
33xterra
2004 2005 Xterra
thanks.
I don't understand how some can be messed up and some be fine. Could it be because of Like carbon buildup or something? Or just a matter of howany revolutions the motor did after it broke? Oh and technically it didn't "break" just teeth got ripped off at the crank pulley. Does that make a difference. Sorry for all the questions but my duramax is gear drive so I don't really know too much about timing belts lol.
33xterra is offline
2004 2005 Xterra
post #4 of 7 Old 09-08-2012, 08:25 AM
muadeeb
Banned
It all depends on where the valves are in the cycle. Most break by shearing teeth.
My pulley was rust welded onto the crank shaft and the shop I went to had to cut it off. Broke one puller, and stripped out a hole trying to get it off. Try heat, PB Blaster, gentle persuasion to get it off.
muadeeb is offline
post #5 of 7 Old 09-08-2012, 05:26 PM Thread Starter
33xterra
2004 2005 Xterra
ok thanks for the tips. hopefully I'll get the new one tonight.
33xterra is offline
2004 2005 Xterra
post #6 of 7 Old 09-08-2012, 06:51 PM Thread Starter
33xterra
2004 2005 Xterra
where does the timing mark on the cranks go? straight down?
33xterra is offline
2004 2005 Xterra
post #7 of 7 Old 09-08-2012, 11:15 PM Thread Starter
33xterra
2004 2005 Xterra
I figured it out. now I can't find how to tighten the tensioner. where does the spring go? I don't remember where it was when I took it off. but good news is that it started right up and ran smooth so I don't think any damage occurred.
33xterra is offline
2004 2005 Xterra
