Location: Surrounded by Jeeps in an Xterra-less Michigan
Member: #33519
D-ring suggestions?
Looking to get a D-ring / clevis to put on my hitch receiver, but don't know where to start. Do I attach it right to the receiver? Use a shaft? Any suggestions or recommended products would be awesome. Thanks!
- Brian (Jack)
| 2002 3.3L 4x4 XE - the Terradactyl |
[x] K&N filter, rear sway bar & side rail removal, repaint trim
[ ] Gobi ladder and low-profile rack
[x] BFG Rugged Terrains
[x] Front & rear recovery points, LOBO, PML
[ ] Xoskel lightbar & PIAA lights, Mean Green alternator
[ ] Full armor - skid plates & sliders, hidden winch
[ ] IAB, Bilsteins, HD TRAs
[ ] Low-profile snorkel, CB installation
Not to stop you from spending your money, but you can just use a hitch pin. It works quite well, it's cheap, and it wont effect approach or departure angles like a large shackle sticking out. Plus, with our already low hanging hitches, a lower hanging shackle just does look right to me. Just feed a looped rope through the receiver, then put the pin through. Success.
Member: #33519
@Dimo - I've heard of that. But I've also heard that from an engineering perspective, that's a big no-no. I've heard both success stories and horrible failures. At this point, I'm thinking of just shelling out the $40~ and going with the "rather safe than sorry" approach.
- Brian (Jack)
The load is carried through the hitch pin regardless of which device you loop your strap to. The only difference is whether you have the strap on the pin or the shackle. Depending on how you loop the tow strap around the pin, you could get an uneven stress distribution/concentration in the pin. The good thing about the receiver/D-ring is it ensures the stress in the pin is always uniform. For most tow jobs, I wouldn't think it would cause a problem, but there is always the possibility. I have no experience either way, this is just a little engineering thoughts off the top of my head.
On a side note, since this is a related thread:
My X has stock bumpers and no trailer hitch. Do I need D-Rings for stock tow points? I've crawled around a little bit under the X and wasn't really sure. I haven't been off road yet, but am working towards having my X trail ready...what are my options?
Rob:
I'd suggest picking up a hitch if your not going to upgrade the bumper soon. The stock bumper mounts are held to the frame with sheet metal and outing a load like a tug in it will just find you staring at a bumper on te ground.
I tried the shackle pin idea before but you can't really get the recov straps loop in the receiver very easily. I use a synth shackle to make it easier.
-Curt
2002 Black Xterra SE 4x4
Build Thread
:Lets just say its getting to be an expensive mod list:
Originally Posted by J Everett
I'd rather attempt to put together a 5000 piece puzzle of nothing but blackness than set the pinion lash on a Dana diff.
OK cool thanks, good to know...I will bump the trailer hitch up a little bit higher on my priority list. Is there any place to recover from in the stock front tow points, or should I just never go somewhere that I can't be recovered from the trailer hitch?
