AC Expansion Valve replacement help - Nissan Xterra Forum
post #1 of 6 Old 06-02-2012, 03:43 PM Thread Starter
raiderfernie
Seasoned
raiderfernie is on a distinguished road
i have been having AC problems for a few years now. about 2 yrs ago, the compressor kepy cycling on and off so i replaced the thermo switch and that problem fixed it. about 2 months later, it would only blow cold when it was below 85 degrees...and has been this way ever since. when its hot as hell its cooler having the windows down. the system has refrigerant and i asked a buddy of mine who is a technician at a Nissan dealer and he said it might be the expansion valve because the AC lines dont even sweat. so i figured, awesome ill just change it out and BAM problem fixed. its a $15 part locally and with refrigerant i was looking at about 80 bucks until low and behold i found out where the damn thing is. i intend to clean the evaperator with spirits and replace with new o rings. has anybody ever changed the expansion valve before and if so, how do you open up the housing enouth to take out the evaperator to change out valve.
raiderfernie is offline
post #2 of 6 Old 06-02-2012, 03:59 PM
RawkerStatus
RawkerStatus's Avatar
RawkerStatus is on a distinguished road
i'm sure it's screws holding it together. sucks having to pull the entire dash and support out
Transmitting from the Death Star
Conveniently off the 10 and 210 in San Dimas... no not really
RawkerStatus is offline
post #3 of 6 Old 06-02-2012, 05:04 PM
Gustling
Guenstling
Gustling's Avatar
Gustling is on a distinguished road
What model is it? On my '02 I THINK it came off by popping the plastic around the gearshift and removing some screws. If you're smarter than I am, you have to remove the gear shift. I found a video on google on how to replace the radio(whole searching for how to get those little circle cutouts just below the AC controls) and that's how I pulled mine off.
Sent from The Dark Side
Gustling
2002 2WD SE
Silverstar headlight and fog light bulbs
Removed mud flaps
Painted rims
Hella 500 Black Magics
B&M Light Bar installed (no lights yet)
Contemplating: PML, BL, tires suitable for mild off roading
Gustling is offline
post #4 of 6 Old 06-02-2012, 05:04 PM
Gustling
Guenstling
Gustling's Avatar
*DON'T have to remove the gear shift...
Gustling
2002 2WD SE
Removed mud flaps
Painted rims
Gustling is offline
post #5 of 6 Old 06-02-2012, 05:11 PM Thread Starter
raiderfernie
Seasoned
i have an 01
post #6 of 6 Old 06-02-2012, 05:44 PM
Gustling
Guenstling
Gustling's Avatar
I bet it's close. Google it and see- I bet it'll help anyway
Gustling
2002 2WD SE
Removed mud flaps
Painted rims
Gustling is offline
