I know all of this information is covered around here, but I found that it was fragmented in different places. I am going to give a full explanation of all things PML and hopefully help a few people understand a torsion bar suspension system and the purpose of the bump stop gaps (two things I have found confuse a LOT of people). Read on, let me know if I missed something or if you have any questions. Really try to understand the mechanics of what is going on if you are new to this stuff because that makes the actual 'doing' a lot easier.
If you know nothing, start here:
http://en.wikipedia.org/wiki/Torsion_bar_suspension
===========INTRODUCTION============
PML = Poor Man's Lift = ~1.5" Suspension lift
Front: Stock torsion bar suspension is adjustable to an extent. This stock adjustment is used to gain an alleged 1.5". Free front end lift.
Rear: Shackles connect the leaf springs to the bottom of the frame. Longer shackles will add about 1.5"
Purchase rear shackles:
The typical ones are the 1.5" shackles:
https://www.4x4parts.com/nissan/xterra-rear-lift-shackles-p-145.html
Some people have complained about not getting enough lift in the front end, and so I decided to go with the adjustable shackles so I could use a lower lift setting in the rear if I needed to. I eventually plan to get upper control arms to add more lift to the front, and then can max out the adjustable shackle at 2 1/8":
https://www.4x4parts.com/nissan/xterra-adjustable-lift-shackles-p-5612.html
If you are curious about how much lift you can get in the front end, place a jack under the front differential cross member, and raise both front wheels at the same time, watching the bump stop gap. Once you have between a ~0.5 inch gap between the upper control arm and the bump stop, you have reached PML ride height, and this will give you a good estimate of you front lift.
Further Explanation on the simulating a lift:
Lifting in the center, you will see how your control arms droop down. You know you have to stop lifting at ~0.5" bump stop gap...so raise the vehicle with a jack on that front subframe cross member until you see ~0.5" bump stop gap on each side.
Stop there and take a look...that is how high your front end will be when you are done.
Now is a good time to check your rake front to back. Do you still have a nose down rake? If so, you may want to just raise the front end, and leave the stock shackles on. if it is higher in the front, or perfectly level, you may want to go for the shackles. Or you may want to get the "Adjustable Shackes" that have multiple sets of holes in them, and dial them down a notch or two so you don't lift the rear as much. You will have shackle hanging off the end of the leaf spring, but you can cut the extra off if you really want.
The issue people seem to run into is that you don't get much lift out of the front suspension and still have an OK bump stop gap. The rear shackles will often raise the vehicle a full 1.5"...but the front will only adjust up 1" or so.
If you started with the nose down rake of 1.5" lower in the front...your ending rake will be 2" lower in the front, for example. Some people don't like the nose down rake, so they are tempted to over-adjust the front end, which can cause some problems. That is why I advise to check the front lift this way by "simulating" a lift in the front, THEN deciding what to do with the rear.
===========PREP WORK============
Prior to lifting anything, find a FLAT surface to work on (evenly laid garage floor is nice!). Ensure your tires are properly inflated. Ideally your tires should all be about the same tread height too.
Take preliminary measurements with a tape measure of your current ride height and write them down so you know where you are starting off at! Measure from the ground to the bottom of the doors right near each wheel well (not the wheel arches)
Measure the front:
Measure the rear:
Locate the rear shackles and the torsion bar adjuster bolts and nuts. Grab some PB Blaster or my favorite, Freeze Off! Drench all the hardware with some chemicals to keep them from being rust welded and breaking off. I started about a week before I was going to do the lift because mine looked really bad. I sprayed them all once, waited about 5 days, did them again, and sprayed them again on the day I did the lift. Maybe over board, but it definitely made things much easier.
Chemicals:
Front torsion bar location and functional diagram:
Adjuster bolt, near mid section of truck. Spray bolt head, and both nuts above cross member.
On top of adjuster bolt, through cross member...two nuts...top nut is just to lock the bottom nut so it doesn't rattle loose.
Rear shackle location:
Spray shackle hardware:
Measure the front:
Measure the rear:
Chemicals:
