Water/Meth injection and 93 tune? - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Nissan Xterra Mods > Performance Mods
Old 04-13-2012, 07:40 AM
samcf samcf is offline
Member: #32948
2007 Xterra
samcf is on a distinguished road
New Xterra owner here. It's a 2007 and I installed the Superchips Cortex. I love the 87 tune and I really want to try the 93 tune. My problem is that its hard to even find 91 octane and I have never seen 93 around here.
I have Water/Meth on a turbo atv and a Diesel truck and it works awesome in those applications. It cools and raises the effective octane rating.
I'm thinking of running Water/Meth with 87 octane, and loading the 93 octane tune on the Superchips. I would love to hear everyone's thoughts on this.
(Snow Performance claims that if you are running 91 octane the Water/Meth takes the effective octane to +/- 116)
Old 04-14-2012, 06:50 AM
malikinam malikinam is offline
Member: #32972
2012 Xterra
malikinam is on a distinguished road
Looking forward to this event! Great work getting this to happen Dave!
what is seo | celebrity hairstyles | fashion world | real estate market
Old 04-14-2012, 09:39 AM
silverbullet's Avatar
silverbullet silverbullet is offline
ASE Certified
Member: #2959
silverbullet will become famous soon enoughsilverbullet will become famous soon enough
running higher octane in a vehicle designed for 87 can do some serious internal engine damage if run for a longer period of time. From a longevity stand point I wouldn't recommend it.
Old 04-14-2012, 10:09 AM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
I use 89 all the time. Will that harm anything?
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 11-19-2012, 04:29 PM
XUGG XUGG is offline
Member: #1893
XUGG is on a distinguished road
This is out of a 2nd gen manual
tldr: "nissan recommends octane of at least 87 (research octane number 91)"
Old 11-24-2012, 04:02 PM
Mandic Mandic is offline
Member: #33423
Mandic is on a distinguished road
Umm, what?
Octane is a rating system for the ease of ignition of gasoline. It is still just gasoline. Higher octane fuel is harder to ignite, but still burns just fine. It will not cause any damage to engine internals. It will reduce power output. An engine will always produce the most power it can(with its settings and tune) on the lowest Octane it can safely run.
That said, if you run too LOW of an Octane fuel in an engine designed for higher it could cause serious engine damage. An engine designed to run on 91+ fuel has some characteristics requiring higher Octane. Say higher engine compression ratio, boosted applications raising the effective compression(turbo/supercharged) or the timing characterstics. Basically the only thing in chips and programmers that requires a higher fuel octane level is usually total timing and the timing curve.
If your car or tune are supposed to run on 87, running 89, 91, 93, or 94 isn't gaining you any power, but it isn't hurting the engine any.
Sorry to go off on that. Now Water/Meth does NOT raise Octane rating. What it does is cool the intake air charge and reduce cylinder temperature. That lowers the octane requirement. Like the old story of a top fuel dragster burning out their spark plugs by the 1/8" mile and just running on the hot metal the rest of the way. A hot spot in a cylinder head can cause pre-mature ignition(commonly referred to as detonation). Which causes serious engine issues. Water/Meth helps reduce temperatures preventing that occurance. Diesels don't have Octane ratings, they go off Cetane, and for them Water/Meth is just reducing intake air charge temperature. Cooler air is denser air. Denser air means more air, so you can get more fuel.
Here is a video I just found that is actually pretty good:
Now with all that said. Water/Meth will serve no purpose for you. It isn't meant to be injecting ALL the time, so it wouldn't function for your raised octane requirement. Also it isn't intended for Naturally Aspirated engines at all. They just don't have the same situations that forced induction does. May it make a difference? A bit. Any noticeable difference? No.
If you live somewhere you cannot get access to the octane requirement for the tune or modification you want, look harder, or don't do it. Running on too low of an octane could cause SERIOUS engine damage. And all it takes it that one time you are away from the one station around that sells 91 octane.
Oh and Octane booster additives are not a safe alternative either. Don't go thinking you can run a hotter tune if you just dump an $8 bottle in at every gas fill up.
Old 11-26-2012, 07:11 AM
rjr162's Avatar
rjr162 rjr162 is online now
Member: #8871
rjr162 will become famous soon enoughrjr162 will become famous soon enough
See if you can't find a Sonoco station near you. Not sure if yours will or not, but the Sonoco's around here tend to carry 87, 89, 91 and 93 (that's according to Sunoco's website although I was pretty sure they had a 94 at that station as well)
