M226 seals leaking - Nissan Xterra Forum: Xterra Forums
Old 03-31-2012, 06:04 PM
dezurtrat's Avatar
dezurtrat dezurtrat is offline
Mindless Modding Moderator
Member: #2413
2008 Xterra
dezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of light
M226 seals leaking
So, I smelled burning coming from drivers side rear wheel. Pulled wheel thinking I was maybe leaking brake fluid. Pulled caliper but then I could see no leaks around the caliper but wet spots around the center of the axle. Figure the axle seal was leaking. Then I started checking around and the front diff seal is also leaking.
I grabbed the breather but it rattles around. I have read they can plug pressurizing the axle pushing fluid past the seals. Do I need to pull the breather off to make sure its not plugged? When I put my blue torch diff cover on I noticed air escape when I removed the fill plug which I thought should not happen if the breather was working. Which leads me to ask is there any reason that adding the diff cover would cause me an issue?
I went ahead and did the breather mod. I then checked the diff fluid level and this time no air escaping noise this time when i pulled the fill plug. I looked at the fill plug on the blue torch cover and its pretty high. I just wonder if you can over fill to the point that the axles are filled to the top and no room is left for air to move out the breather.
I've never worked on axles and feel a little nervous about it. I have an extended warranty through GEICO but not sure seals are covered and not sure that diff cover will cause questions.
Old 04-22-2012, 10:46 AM
dezurtrat's Avatar
Member: #2413
2008 Xterra
BTW, found a Nissan Technical Service Bulletins (TSB) on this issue. I'll post it up later.
Old 07-27-2012, 11:00 AM
Miller5103 Miller5103 is offline
Member: #13832
2007 Xterra
Miller5103 is on a distinguished road
Did you ever take on the job of replacing the seals? Both of my rear axle seals are leaking and my rear pinion seal is leaking. Dealership is telling me it will be ~$950 to replace seals/bearings (had it in for the fuel sensor fix). I'm thinking about taking the job on myself since parts are only around $250, but haven't worked on axles before. Wondering how difficult it was if you did it.
Old 07-27-2012, 11:22 AM
SamsXE's Avatar
SamsXE SamsXE is offline
Member: #33065
I would find a transmission/alxe shop, they could probably do it faster and have more knowledge about how a alxe operates than a shop tech reading the how-to on the computer. (not saying nissan techs are incompetent but not all of them rebuild axles every day)
My Build Thread:
Old 12-05-2012, 03:02 PM
oharag oharag is offline
Member: #37044
2005 Xterra
oharag is on a distinguished road
I've had my rear seals leak since I bought the car in 2005. I had the seals replaced under warranty a number of times (maybe twice). They leaked again. I found information on the internet showing others had the same issue. I had 5 yr/100,000 extended warranty and had a whole new rear drive train installed under warranty. Now some 75,000 miles the rear seals are leaking again. I was informed there is a service bullentin dated JAN 2010 - maybe before my new drive train was replaced - noting this issue. I called 1-800-NISSAN1 to file a complaint. They told me to take it into a Nissan dealer for diagnosis - obtain a cost and then they will contact Nissan Corp. I told this women - does this mean you will resolve the issue after I wasted my time and money - and she said no - though there may be a resolution. What the heck - I'll give it a try.
Old 12-16-2012, 09:45 AM
dezurtrat's Avatar
Member: #2413
2008 Xterra
Well, this turned out to be almost a disaster had I not had a after market warranty. Dealer f'd up my axle by not putting enough fluid back in. Said I had too much fluid due to my after market rear diff cover which they said caused the seals to leak because it plugged my breather. BS, I checked the breather and it wasn't plugged. Besides, there are many xterras out there with this issue thus the reason Nissan issued a TSB. Duh!
So, not enough fluid destroyed the pinion bearing and ring gear. I had to have a new axle put in. I'm done with dealers. A bunch of f'ing idiots. My aftermarket warranty saved me $3,000!
If that was not enough, Nissan charges $3k for a REBUILT axle or $3.3k for a new one. Nissan go F u c k yourself. Unreal.
My shop wanted to rebuild it but Nissan won't sell the parts. My guy says he's never seen an axle in all his years that couldn't be rebuilt! Junk.
Old 12-16-2012, 02:22 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Well that sucks.
  #8
Old 12-16-2012, 09:30 PM
dezurtrat's Avatar
Member: #2413
2008 Xterra
Originally Posted by RacerXXL View Post
Well that sucks.
You aint kidding!
I was in a rant mood. Nissan missed the boat on the Gen 2's IMHO and ESPECIALLY that M226 with the locker.....
